Dacor Epicure ERD36 Dual Fuel (Electric and Gas) Kitchen Range Logo
Posted on May 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The lower electric heating element in the oven does not heat
The gas powered broiler works normally
Anonymous
Level 3:
  • Dacor Master 43,501 Answers
  • Posted on May 11, 2010
Anonymous
Dacor Master
Level 3:
Answers
43501
Questions
0
Helped
10838010
Points
101584
If your electricthe lower electric heating element in the oven doe - 2_bing.gif oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
1helpful
Oven baking element lower heat source doesn't heat
Check valve for power, if power is there than look for part elswhere as 166 is a lot. Mine was 40 but you do not state make or model
Broiler element doesn't work
Reseating the Element The broiler is heated using an electric element which should be clipped in to the top of the broiler enclosure. If this has come loose then it might not be making contact with the necessary terminals. Try to reseat the terminal but before doing so you must ensure that the electricity is turned off.
Testing the Element The element is what heats up and cooks the food in the broiler. Over time the heat can damage the broiler element. These elements are supported by stand-offs and if the element burns out or becomes damaged then this can be a common reason why the broiler isn't working.
The easiest way to test whether this is working is to turn the broiler on and look at the element. If it is working correctly then the element should be glowing red.
Another slightly more complicated test for the broiler element is to remove the element from the oven and disconnect it. Then use a multimeter to check the continuity of the element. Set the multi-meter to measure resistance and then put it either side of the element. The normal measurement should be between 20 and 40 ohms. If the element is infinitely resistant then this means it's broken and will need to be replaced.
Testing Oven Controls Another reason why the broiler will fail to work is because of problems with the oven controls. A thermostat is used to set the temperature of the broiler, and the oven selector controls are used to control the setting of the broiler.
Turn the oven controls on to see whether the broiler is working properly. If not the controls can be removed and tested using a multimeter. Check the outputs to ensure that the controls are working correctly.
These can also be replaced if required by fitting a replacement part designed specifically for your oven.
Read More: Troubleshooting an Oven Broiler Doesn Work
My oven broiler does not seem to be working-I turned it on broil for about 15 minutes - no heat, nothing. On normal bake, it takes about a half hour to heat the oven to 350 degrees - my old stove took...
check the bake (lower) element, mine just went out. It was easy to spot the problem once I pulled the element out, the wire had burnt off the end. Please remember to turn the power off first.
3helpful
Bake does not heat up. Broil works though
I'm going to take a wild guess and say that you oven has two heating elements. A lower one for general baking and an upper one for broiling (this means that you don't have a broiler "drawer").
If this is the case, then the problem exists with the pilot/ignition system for the lower heat element.
The systems vary by manufacturer, but the type that I'm familiar with involves and electrical heat element that ignites the gas once it starts glowing. It's possible that a wire has been damaged/disconnected or that the heat element has malfunctioned.
If your oven has a pilot, then it's possible that the pilot went out on the lower element and not the upper. Last option would be an electric "spark" style ignition which may have suffered from the same problems as the electric heat element mentioned above.
Oven does not heat, except for broiler
wat ur oven electric or gas, if electric the 1 posible coz is damage the thermostat
or the heating element,if ur oven is upper & lower heating element,check if the two element is not heating the coz is thermostat, if gas many coz of problem, 1 pilot ligth,2 gas valve, hard to replace the parts if gas oven also dangerous to replace if u are not the technician or have some idea to replace it,much better to call the person that have an expireince to repair.one again do not try to replace if gas oven.
tnx gerbee
3helpful
Maytag electric oven - MER5770AAQ. lower heating element not work
Hi, Unplug the oven and remove the element to test it. Check the element and see if there is continuity. If the element is open, replace it. It can be bad even tho it doesn't appear bad.
I hope this helps you.
Vic
Jun 20, 2009 • Ovens
Oven won't light, we smell gas. Broiler works fine.
I have seen an oven with an electric Broiler element and a lower gas burner but not one with electric top elements and gas below.
SO Im fairly confident your total electric on this appliance. You will have to check the element and if its ok the voltage to the element. If it has a timer the timer could be keeping it off. check the settings on the timer and see if it will click when advanced. Wait a few min then the oven heat up after a few minutes.
1helpful
Kenmore electrical oven
Trying to better define the problem....
Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
Heat elements in oven/broiler do not heat up
I would say to go and reset your curciut breaker first if this is a electric oven. needs 220 volts for both element to work
Oven does not Bake, Heat Up
Replace the oven glow bar igniter. If you post an exact model number (located on sticker behind lower drawer) I can give you a part number.
Top Dacor Kitchen Ranges Experts
Paul Carew
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
