It seems that the refresh rate of the tv is causing an issue try doin a hard reset
switch off ur tv
remove power cable from mains.
keep power button pressed for 15 seconds
then turn on the tv
try the step and let me know...i will provide u with further steps
is it that the tv would go off and come on or is it that the tv is taking too long to show the picture after changing a channel
well that means its an issue with the refresh rate of ur tv...plz contact the vendor of ur tv so that they can reset it to factory defaults
I tried your advice. With no input signal TV comes on and stays on (tried for 5 minutes). However when ever I change channels, the tv actually goes off and then comes back on. I remember now that is how the problem started. Thanks
When I change the channels, sometimes it takes a short time for the channel to change, but most of the time, I can hear the crt discharging, the screen projects a series of snow, vertical and horizontal lines, then the channel comes in.
