Fedders A7DH45B2A Dehumidifier Logo
foobar sdg Posted on May 10, 2010
Water is not collecting in the bcket. I have had this on and it
Runs but doesn't collect moisture. Since my basement is wet this spring I would think it should be collecting some moisture.
Anonymous
Level 1:
New Friend:
  • Contributor 26 Answers
  • Posted on May 10, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
26
Questions
0
Helped
8680
Points
33
Whats it set on, check and verify the the compressor running if not wont pull out any humidity
Unit is not collecting water and carpet is wet
Unplug it and let it dry out. Place it on old newspaper and start. Check the paper and look for the wet spot. That will let you know where the water is coming out of the unit. Check that area, it is probably a bad seal on the drain or a crack in the water container.
1helpful
Whirlpool dehumidifier ad35dssi runs, but doesn't collect any water, even in a wet area. Have cleaned filters, no luck.
Glad to hear that you thought to clean the filter, as that would have been one of my suggestions. Because, it's the most overlooked.
But, there is another one that equally overlooked and is probably the number cause of your humidifiers problem. The humidity extraction level is set to HIGH. Lower it to 32 - 35%. If your unit does not have an LED Screen readout, set the control on MINIMAL.
This is what gets confusing about the use of dehumidifiers. They work backwards from what most people think. The lower the setting, the more moisture/humidity is extracted from the house. The higher the setting/numbers, the more humidity remains in the house. The higher setting would be used only in the Winter, because removing all the moisture and humidity will make the house uncomfortable.
If this wet area, you mentioned is a basement. The ambient air temperature at floor level is colder than at chest level and dehumidifiers don't work well in temperatures between 40 & 60 degrees F.
If this is the case, placing the unit up off the floor on a sturdy table, counter, etc that can hold the weight of the unit, plus a full bucket of water will generally solve the problem.
Also, be sure that you're maintaining at least 12" of clear air space on all sides of the unit. If the air flow is obstructed, the unit will run all day and not extract any water.
Hope this helped you troubleshoot and solve the problem. Please let me know. Thanks.
My Whirlpool dehumidifier runs, but compressor does not come on.......we do have moisture in the basement because the basement recently had a water problem.....and typically the compressor would come on....
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Front has moisture on fins, runs but does not take out much water even though basement is real wet, I noted the whole front was frozen last week...
There can be many reasons why a dehumidifier willnot work or collect water.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
MY DEHUMIDIFIER RUNS BUT NO WATER IS COLLECTED AND I CAN FEEL MOISTURE IN THE AIR IN MY BASEMENT
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
I have the dehumidifier in the basement and turn it on; it ran for a day and no water collected in the lower bucket. Am I doing something wrong? I would think it would pick up some moisture in the...
heatman101
2helpful
No water collecting in bucket.
There are many reasons for a dehumidifier tto not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier.
heatman101
Dehumidifer stopped collecting moisture, blows air w/ empty tank
Possible cause it's out of gas.
you might have to get a refridgeration mechanic to regas it, or/and fix any gas leaks
2answers
Collecting no water
My crosley dehum. acted the same way. It turned out to be a bad defrost thermostat on the evaporator coil.
Top Fedders Dehumidifiers Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Fedders Dehumidifier Expert? Answer questions, earn points and help others
