SOURCE: SAMSUNG Microwave Oven Model MD800WC/SC The
my problem you cannot push the digital number what's wrong with my mocrowave, sometimes it comes the time and then as soon as you push the time to heat it stops no power?
SOURCE: Samsung Microwave Oven shows -SE- on the display. Why?
-SE- error means you
have a shorting membrane keypad.
Since
it's less than one year old, it would be fully covered under warranty.
I'd suggest contacting the manufacturer to get it fixed free.
You can find your
nearest Samsung-authorized service center here or call Samsung's Service Division at 800-932-3837.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
SOURCE: flashing dispaly of 4 eights, with no response from keypad
Try to press Stop/Clear. If that doesn't clear it out the keypad may be defective.
SOURCE: Kenmore microwave - unresponsive keypad
Repaired the unresponsive keypad on my older Kenmore (model 721.68100): Unplug. Remove integral cover for top and sides which is held in place by 5 metal screws. The cover then slides toward the rear. Unplug two connectors to back of keypad and clean them (I used contact spray cleaner). Some of the components retain a charge even when unplugged.
SOURCE: 5E (SE) error showing on
The "SE" error indicates a shorted membrane keypad.
You can find support from Samsung in India here.
Have you lost power recently?? Try pushing the clock pad and see if you get any response from that. Some units will not take any programming until the clock / time of day is set.
