I have a Kenmore spacemaster microwave Auto recipe 300 that needs a part but the model number has warn off. How can I find out the model number?
Deric......
If you didn't locate that model number yet, the number should be 5648698510. I have the same unit and just had Sears do a minor repair on it. Luckily, some but not all parts are still available, so check the Sears Parts site to see if what you need is available.
Dead appliance, power on wall outlet.
YOUR
SAFETY IS PARAMOUNT!
Attempt
this only if you are competent.
If
your appliance has absolutely no functions at all, remove it from the
mains supply, remove the case and see where the mains lead goes in to
the appliance and follow the cable until you find the main fuse.
ONLY
USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual
cause of this fuse failure is the door switches are contaminated or
sticking. Check the door switches before putting power back on to the
appliance.
Hope this helps.
Is there an FCC number visible on the tag? If so, please post back with that complete number.
Do you have the manual? It should be there.
Is the serial number visible? Sears should be able to find your model number that way.
What part do you need?
model no 564.8755380
can u get new fan
