Philips 55PP9352 55" Projection Television Logo
Anonymous Posted on Mar 28, 2008
55 hdtv philips having issues with blue and red lines around everything ......
55PP935217 PHILIPS HDTV I THINK ITS A 55 INCH PROJECTION HDTV....
HAVE RED AND BLUE LINES AROUND ALL THINGS THAT APPEAR ON SCREEN .. WENT TO A SETTING TO TRY TO MATCH UP THE BLUE AND THE RED ON THESE CROSSES YOU MIGHT KNOW WHAT I MEAN AND RESET FACTORY SETTING BUT IT DIDNT HELP . NOW GETTING WORSE ..HELP
  • 5 more comments
  • Thomas Trubenbach Apr 13, 2008
    > change the convergence ICs also check the resistors right next to the
    > ICs as 1 or 2 of them may be open as well.
    What is an IC, and where can I find the IC and resistor?
    Thank you.
  • Thomas Trubenbach Apr 14, 2008
    What is an IC and where can I find them? Also what do I do if the resistor is open?
    Thank you.
    Trube
  • tothetrack48 Oct 06, 2008
    Mine is not red and blue, but just red lines. Would changing the convergence I C solve the problem and where is it located?
  • Anonymous Oct 15, 2008
    I have the same problem with the convergence ICs. I ordered the new ICs andinstalled them. Made 100% sure about the solder job. Fairly easy job. Now picture is worse than before. Before I could adjust the vertical convergence, now I can't control vert. or horz. Also the picture is bowing in from the top and bottom and the picture is extremmly red in color. A friend told me I might have the IC box(silver box) not plugged in properly with the ribbon wires. Any ideas? Thanks in advance.
  • hd85anniv Dec 13, 2008
    Philips 55PP935217
    Hello ,
    I'm having similar problems, when I go to manual converging I can see the blue appears to be lined correctly?
    When I try to line the red to green it will not work.
    I can move the the + around to each location but cannot get them to line up together.
    I keep reading about the IC'S, could this be my problem?
    I do not want to open the back of the set until I know a solution.
    I will order a set of IC'S if this may be the problem?
    Where would be the best location to order?
    Can anybody tell me how to locate these chips on the board or is it obvious when I have the new IC'S?
  • lfounta1 Apr 03, 2009
    color is messed uo. picture curves. looks like blue and green are ok, butthe red is off. tried to allign it, but didn't work. no tv repair men in my area. i'm pretty handy. any ideas,and if so where do i start. th tv is only 4 years old.
  • Anonymous Mar 26, 2014
    how do I fix my TV's color from the picture being all red I tried everything.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 05, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
570
Points
An ic (it is usually capatilized as IC) is an acronym for intigrated circuit.
A
Anonymous
What is an ic and no im not a noob
Sonny Berry
Level 3:
  • Philips Master 8,617 Answers
  • Posted on Mar 28, 2008
Sonny Berry
Philips Master
Level 3:
Answers
8617
Questions
Helped
1723396
Points
23750
Change the convergence ICs also check the resistors right next to the ICs as 1 or 2 of them may be open as well.
Picture looks like its red and green 3-d,Phillips 55pp935217
Ur convergence it dead,Need a convergence kit,use what in that kit,Know how to solder righht?Tries Tv Repair World.com,Ebay.com.
55 inch with blue ghost like glow on white or blue colors
Inside of your TV their is a fluid that keeps the tubes cool. Over the years this fluid will turn cloudy and cuase the screen to look dull, bright white, have halos, etc. You can get the fluid over the internet from various sources or your can get a complete kit including repair instructions from www.TvRepairKits.com.
1helpful
No picture just sound in Philips 55 projection hdtv
Check the site www.TvRepairKits.com. They just added a kit for this exact problem.
55pp935217
OK, where to purchase the is focus box? Part number 54945198.
It is not at the philips store. Help!
Philips 55" hdtv rear projection internal parts
If your model number is 55PP935217 you dont have a ballast. You have a rear projection with 3 CRts . Please let me know if thats the correct model number and what your symptons are. I will be able to help you get what ever part youre needing.
There will be several that look simallar but look for the STK 392-120 or 392-110. List the stk numbers that you have and I will let you know which ones are the right ones
www.electronix.com should have them for about 10.00 each they involve soldering and dissasembly of the convergence board. A repair shop will charge between 300 and 400 to do the repair depending on where its done.If you go to the link enter STK392-110 in the search box and that will show you what they look like yours are either 392-110 or 392-120s they both interchange with each other, however STK392-120 are a better chip.
Philips projection screen 55pp9363
HDR LSM ASM is the problem. Philips part number 313503711011. Contact parts store on line at www.partstore.com for part.
2answers
Green dot in middile of my screen
The green dot in the center sounds like a burn mark on one or more of the picture tubes inside the set, and the curved lines are telling me that you have a problem in the convergence circuits. The blue haze around everything white tells me you either have a lot of dust build up on the lens over the CRTs, or your picture tube(s) are very weak. If this set is over about 12 years old, I would replace it. I doubt if you will be able to get the green dot out of the picture without changing the tubes which would be VERY expensive.
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
