How do I change the date ?
The time and date will update automatically when you receive a call as long as you receive caller id from the telephone service provider. Current time and date are part of the Caller ID data stream. Once the time is received the Fanstel unit will keep time from there and it will be updated every time you get a new call.
Thank you for your inquiry, edwin chiu!
Based off the information you have provided your Frigidaire washer is displaying the error code "DDO". "DDO" stands for dispenser door open which could be a problem within your door or reed switch. I would recommend opening and closing you do to secure the connection is proper.
If that does not correct the issue I would perform a reset on your washer which you can do by disconnecting the power from it by either unplugging the power cord or flipping the household circuit breaker for ten minutes. Hopefully this information has been helpful. -Matt
Hello geraldinerid - Typically DDO indicates that the washer has detected a problem with the dispenser drawer. Either the drawer is open and will not close properly or a further diagnosis is recommended to have a professional check the reed switch.
Hello noella_30 - Typically DDO indicates that the washer has detected a problem with the dispenser drawer. Either the drawer is open and will not close properly or a professional needs to check reed switch.
