Hi, I tightened my honda cbf 600's chain but i can not loose it again and now it's too tight.
steps to loosen the chain on a CBF600:
-check the chain tension while the bike is sitting on the kickstand in neutral. It should have 1" to 1.5" FREEplay when measuring halfway between the front and rear sprocket.
-loosen the rear axe nut approx 1 full turn, this should require a 27mm socket.
-look for adjusting bolts on either side of the swingarm, sticking out from the rear plate. There will be an adjusting nut and lock nut on it.
- Loosen the 10mm locknuts on both sides (bringing it towards the rear of the bike) while holding the head of the 12mm adjusting nut from turning.
- Adjust both of the adjusting nuts outwards to loosen the chain, inwards to tighten the chain. 1/2 turn on the adjusting bolt will change the chain freeplay by about 10mm.
- Hold the 12mm nut, and snug the 10mm nut up to it. This will lock the adjusters in place.
- While holding the bike, press firmly on the back of the rear tire, This will move the rear wheel forward, and taking up any slack that was created by loosening the adjusting nuts.
- (Optional step but suggested) Use the hatch marks on the swingarm, just below the axle, to gauge whether the rear axle is adjusted evenly on both sides. Make any adjustments necessary to align the axle evenly on both sides. This will require moving the adjuster on one side ONLY. Consider your chain tension while doing this step (if necessary) since you can either loosen one side or tighten the other. After making any adjustments, press the wheel forward again and re-check your alignment.
- Using a 27mm socket, tighten the axle to the proper torque, which should be around 85 Ft.Lbs. If you are not sure about whether or not the axle nut was properly tightened, be sure to ride the bike carefully to a motorcycle shop and ask them to double check it.
-Finally, check the chain tension and make any adjustments necessary by following the previous steps.
