Hi! I have ASUS Notebook X59SR with LG HL-DT-ST DVDRAM GSA-T40N ATA Device. It recorded well many CDs and DVDs. I was using Ashampoo Burning Studio. But a week ago, when a was burning a DVD-ISO with Ashampoo it failed to burn. I tried two more times with different types of DVDs but the burning failed again. Then I tried to update the firmware of the DVD/CD burner and Windows tells that the latest driver is already installed. I serched the LG Support website for firmware but there isn't any for this device. My current firmware is JR03. I tried reinstalling Ashampoo but there was no success. I also tried to burn with Nero 8 but it failed again. I'm always using Verbatim DVD-R. I'm showing you Nero's error log
Nero Version: 8.3.6.0, Internal Version: 8, 3, 6, 0
Recorder:
Adapter driver:
Drive buffer : 2048kB
Bus Type : default
CD-ROM:
Adapter driver:
=== Scsi-Device-Map ===
=== CDRom-Device-Map ===
HL-DT-ST DVDRAM GSA-T40N E: CdRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 2047MB (2097151kB)
Free physical memory: 1973MB (2021320kB)
Memory in use : 35 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
14:56:59 #14 Phase 24 File dlgbrnst.cpp, Line 1767
Caching of files started
14:56:59 #15 Text 0 File Burncd.cpp, Line 4481
Cache writing successful.
14:56:59 #16 Phase 25 File dlgbrnst.cpp, Line 1767
Caching of files completed
14:56:59 #17 Phase 36 File dlgbrnst.cpp, Line 1767
Burn process started at 4x (5.540 KB/s)
14:56:59 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2673
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
14:56:59 #19 Text 0 File DVDR.cpp, Line 3297
Recording mode: Sequential Recording Mode
14:56:59 #20 Text 0 File DVDR.cpp, Line 3451
Start write address at LBA 0
DVD high compatibility mode: Yes
14:56:59 #21 Text 0 File Cdrdrv.cpp, Line 10187
---- Disc Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 2.1 (33)
Disc Size: 120 mm, Maximum Transfer Rate:
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
Outer Limit of Data Recordable Area: 26127F h
Data in Burst Cutting Area (BCA) does not exist
Revision number of maximum recording speed: 6.0
Revision number of minimum recording speed: -
Revision number table of recording speed: 1.0 2.0 3.0 4.0 5.0 - -
Class: 0, Extended part version: 33
Start PSN of the Extra Border Zone: 2FE10 h
Start PSN of Physical format information blocks in Extra Border Zone: 2FFA0 h
Media Specific [16..783]:
00 60 00 10 20 30 40 50 - 00 00 00 21 00 00 00 00 .`...0@P...!....
00 02 FE 10 00 02 FF A0 - 00 00 00 00 00 00 00 00 ................
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
01 40 C1 FD 9E D8 52 00 - 02 85 0D 0E 88 9A 80 00 [email protected]....
03 4D 43 43 20 30 33 00 - 04 52 47 32 30 20 20 00 .MCC.03..RG20...
05 88 80 00 00 00 02 00 - 06 09 0B 14 87 78 90 00 .............x..
07 88 80 00 00 00 00 00 - 08 08 13 0D 11 0C 08 00 ................
09 95 07 0E 0B 78 88 00 - 0A A0 00 20 00 20 10 00 .....x..........
0B 06 1A 17 86 67 85 00 - 0C 99 AB 3A 83 20 32 00 .....g...:..2.
0D 00 00 D0 00 00 00 00 - 0E 0A 24 35 2F 29 1A 00 .......$5/)..
0F 50 1B 29 17 97 B5 00 - 10 88 80 00 00 00 00 00 .P.)............
11 00 00 00 00 00 00 00 - 12 09 2E 37 2F 29 19 00 ...........7/)..
13 50 1B 29 17 97 B5 00 - 14 88 80 00 00 00 00 00 .P.)............
15 00 00 00 00 00 00 00 - 16 09 3F 44 3D 24 29 00 ........?D=$).
17 60 1F 2F 1D 97 B5 00 - 18 88 84 00 04 00 04 00 .`./............
19 00 00 00 00 00 00 00 - 1A 08 57 46 42 27 24 00 .......WFB'$.
1B 70 1F 2B 0F AA B5 00 - 1C 88 84 00 04 00 04 00 .p.+.........
1D 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ...............
14:56:59 #22 Text 0 File DVDR.cpp, Line 3589
Reserved Track size: 1063072 (1038A0h, 2076MB) -> return code 0
14:56:59 #23 Text 0 File ThreadedTransfer.cpp, Line 269
Pipe memory size 83836800
14:57:22 #24 SPTI -1135 File SCSIPassThrough.cpp, Line 214
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1135)
CDB Data: 0x2A 00 00 00 00 00 00 00 20 00 00 00
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
Sense Area: 0x70 00 03 00 00 00 00 0A 32 4D 03 0C 0C
Buffer x190b0040: Len x10000
0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
14:57:22 #25 CDR -1135 File Writer.cpp, Line 306
Write error
E: HL-DT-ST DVDRAM GSA-T40N
14:57:24 #26 Text 0 File DVDR.cpp, Line 3857
EndDAO: Last written address was -1 (FFFFFFFFh)
14:57:24 #27 Phase 38 File dlgbrnst.cpp, Line 1767
Burn process failed at 4x (5.540 KB/s)
14:57:24 #28 Text 0 File SCSIPTICommands.cpp, Line 287
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
14:57:26 #29 Text 0 File Cdrdrv.cpp, Line 11450
DriveLocker: UnLockVolume completed
14:57:26 #30 Text 0 File SCSIPTICommands.cpp, Line 450
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLMSoftwareMicrosoftWindows NTCurrentVersionWinLogonAllocateCDROMs : 0 (Security Option)
Please help me if you can. Thanks
please try those firmware, seems to be preety recent like for ATA.
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R209974&SystemID=INS_PNT_PM_1525&servicetag=&os=WLH&osl=en&deviceid=19846&devlib=0&typecnt=0&vercnt=1&catid=-1&impid=-1&formatcnt=1&libid=32&fileid=295129
Cheers,
Mike
Leave rate if I helped you, thanks!
Testimonial: "Thank you very much. The new firmware solved the problem. Now it burns everything. Again, thanks a lot"
Hey, there you go:
http://files.rpc1.org/index.php?act=cate...
I downloaded the driver but the installer says that it can't find the target drive. Maybe because it is HL-DT-ST DVDRAM GSA-T40N not HLDS GSA-T40N, like the driver is.
