HP Photosmart D7160 InkJet Printer Logo
Anonymous Posted on May 08, 2010
Photosmart D7360 leaks black ink out the bottom of the case, below where printer head parks. Otherwise works fine.
  • Anonymous May 08, 2010
    I'll need help getting the cover(s) off without wrecking them. Any tips?
Anonymous
Level 3:
Guru:
  • HP Master 1,705 Answers
  • Posted on May 08, 2010
Anonymous
HP Master
Level 3:
Guru:
Answers
1705
Questions
Helped
402340
Points
5112
Its a sponge in the drip tray underneath the print head. It tends to fill up, especially if you're cleaning your print head quite often.
Its full of ink, and so needs to be dried out. The easiest way would be take it out, rinse it under the tap and leave it somewhere warm to dry out.
If you can't take it out, try and decant the ink, blotting paper, sponge as best you can and give it a while to dry.
    Not sure, you should be able to get at them from the cartridge bay.
    Here's a url for the user manual:-
    http://www.retrevo.com/support/HP-D7360-...
    On page 40, it deals with cleaning the cartridge contacts, its it accessible from there.
    These things are a nightmare to get at, I've a different HP photoprinter and its got tamperproof screws
    Another thought, you could try the HP support pages, to see if there's a forum where someone has had the same problem and resolved it.
    Sorry, I can't think of anything else which may help.
HP Photosmart D7360 ink system has failed. How do I fix this?
with 2 new cartridges installed, shut the machine off and back on again.
2helpful
ERROR 0xc18a0001 Ink system has failed Quite new
Try the link below. This error is related to air in the lines between the print head and the cartridges. It is quite common and HP are very aware of this.
http://fix-your-printer.blogspot.com/2009/03/ink-system-failure-on-hp-photosmart.html
I hope this helps. Regards GM
Photosmart D7360 - message says "ink cartridge empty. To print in color, install the following cartridges: yellow. To print in black ink only, press o.k." I have replaced the cartridge (yellow) and the...
go to hp support>d 7360 >software and drivers. Download (run) latest diagnostic utility 2010-11-09. run test and print test page (only one sentence). worked for me. Took about one minute.
No I see no solution noted here. again Photosmart D7360 error message 0xc18a0001 ink system failure.
If you have lots of flashing error lights or electrical problems then it is likely to be electrical.
However, if like most... and your printer has just been left unused for some time? You probably have an ink clog on the cyan and magenta.
Provided it worked OK before a period of non-use? Then you just need to use a PRINT HEAD CLEANING KIT to unclog the tiny jets.
Magic Inkjet Flush usually works a treat on those!
Magic is ideal for unclogging the tiny jets on any Canon, Epson HP andremoving those horrible white lines which usually appear in prints whendried ink clogs several jets...
So if yours appears to be a clog? all you should need to do is to usethe Magic Inkjet Flush kit to soak the print head and you should beprinting again like new.
You can read more here:
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
Also this may help...
HP 145 Sequence HP D145 all-in-one printer
http://magicinkjetflush.com/images/PDF/HP_135_Sequence.pdf
or smaller file
http://magicinkjetflush.com/images/HP_135_Sequence.jpg
Good Luck!
Tinteiros (Ebay)
3helpful
How to take apart HP photosmart D7360
My HP D7360 won't print. Its says the "ink system has failed. Unable to print. Refer to printer Doc. Error: 0xc05d1281" Now, I lifted the printer up and it sounds like a screw bouncing around on the inside. How do I take this thing apart to find the screw and put it back in it's place???
2helpful
How do you open HP Photosmart D7360 Printer case? We had a paper jam and part of the page ripped and we can't find it. I think it may be stuck under the print head.
Hold the bottom base of the printer with one hand, grasp the top cover under the HP logo, and pull upward with the other hand.
4answers
Ink system failure
have you unpluged it from the outlet? can you see any paper stuck?
otherwise you have a bad system board and would cost more to fix than just to by a new one.
HP Photosmart D7360
HP support decided it could not be repaired on line, agreed to replace it but found it was a few days out of waranty...so it is dead in the water. Probably not cost effective to repair it.
Black ink leaking from bottom of printer!
There is a small hopper inside of the printer, called the cartridge holder, this is where the excess ink is wiped off of the cartridges, and is just left there. it is usually on the side where the cartridges stay when they are idle. The easiest thing to do, is take the cover of the printer off, and blot the ink out of the hopper, do not use any detergents, or liquid cleaners, as this will ruin the cleaner head for the cartridges.
k24674
Grand Canyon Tech
Grand Canyon Tech
