I have a cordless Philips twin phone model CD 245...., from one moment to another stopped working and only message screen is showing on both handsets is "searching", I ve tried by disconnecting and reseting both handsets as well as swaping them from each base but they are just not working ... phones just don't have any dial tone at the moment
I want to use two old hansets with a new base station. cannot unregister or reset cordless handset from base station (Which is faulty) want to register two handsets with a new base station I just bought. Philips tell me it was not possible if old base station faulty and not responding to handsets. Any ideas, dont mind taking things apart and using soldering iron.
You can't post conmments that contain an email address.
hello there i think this is because you need to register the second handset with the base here are the instructions
REGISTRATION
Registration links the base to a cordless handset. Once a handset is
registered it can use the base’s phone connection. A cordless handset will
not operate until it is registered to the base. During the registration
process, keep the handset near the base.
1. Press the flash/program button on the base until LINK HANDSET shows
in the display. 2NO is the default setting.
2. Press the 1 number key or press the MESSAGES/CID (or) button
on the base to scroll to 1YES.
3. Press flash/program to confirm handset is linked to the base. WAITING
HANDSET REGISTRATION shows in the display.
4. Press the flash/program button on the handset until LINK BASE? shows
5. Press 1 on the handset keypad or cid/vol (or) button on the
handset to scroll to 1YES.confirmation tone when the handset is successfully linked to the base.
6. Press flash/program on the handset again to confirm. You will hear a long
please leave rating if you find this usefull hope this helps thanx for using fixya!!
I had the same problem, and restoring to default settings did not seem to work either. I just opened the back, unplugged the battery, plugged it back in, and now it works again.
press bottom left button and then hold down 7. display will show 0-0 to indicate its turned on. 2 to read messages. 3 to skip to next messge. 4 to record your message. 5 to listen to current welcome message. 6 to delete messages. 7 to activate answer machine. 9 to deactivate ans mach. 0 to record internal memo. To use any of these functions bottom left button must be pressed first.
yes same problem as he mentioned. please help me to repair it
