Might be a wire broken from vibrations or the MCU itself.
I have a service manual for you. Use the manual to reference repairs and your machine's tech sheet for error codes. This is your F-11 error from your tech sheet:
F11 Serial communication error
Communication between the Central Control Unit (CCU) and the
Motor Control Unit (MCU) cannot be sent correctly.
Possible causes/procedure:
1. Unplug washer or disconnect power.
2. Check wire harness connections to the MCU, the motor, and
Central Control Unit (CCU).
3. Check the drive system for any worn or failed components.
4. Plug in washer or reconnect power.
5. Verify CCU operation by running a Diagnostic test or any
cycle.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
8. Check that the serial harness at the MCU is not mounted
upside down. The wires should be to the left when facing the
MCU connectors.
I have some more photos and repair manual for duet sport model HERE If you need further help, reach me via phone at
https://www.6ya.com/expert/dan_73bbd84fe1d95b61
