Life Fitness 95Ti Remanufactured Treadmill Logo
A
Anonymous Posted on May 07, 2010
95Ti Remanufactured Treadmill: where can i get a new belt from for a 95ti treadmi...
Where can i get a new belt from for a 95ti treadmill & how much? also could i get a manual or instructions to fit and tension the belt
  • Anonymous May 11, 2010
    I need to know the serial number. Life Fitness changed the style walking belt during this unit. They went from a wax system to a waxless system and the belts and decks are NOT interchangeable.
Misael
Level 1:
New Friend:
  • Contributor 19 Answers
  • Posted on May 14, 2010
Misael
Contributor
Level 1:
New Friend:
Answers
19
Questions
0
Helped
17067
Points
28
Fitness Repair Parts. About $400.00
1helpful
Heart rate Monitor not working on Life Fitness 95Ti Life Pulse
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
I would suggest removing your heart rate grips and inspecting the contact leads for rust or any other corrosion. This is very commonly an issue and can be resolved by either cleaning the contacts or simply replacing the parts. Using the following link, and your serial number, you should be able to find the contact grips if you end up needing them.
Repair Parts for LifeFitness 95T 95Ti 95Te Treadmills Midline SPORTSMITH...
2answers
Hello im getting a startup error when i press the quickstart button on my 95ti treadmill.
when I start up my treadmilll across the screens reads Motor-comm error. what coulld be the problem.I keep it clean and dirt free.
Free manual for 95ti lifestyle treadmill.
You could have a look at the manual on :-
http://www.scribd.com/doc/38647127/Life-Fitness-95Ti
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
2answers
Life fitness 95ti belt moving to one side any way of correcting
If the walking belt has shifted to the left, use the Allen wrench to turn the left rear roller bolt clockwise 1/2 of a turn; if the walking belt has shifted to the right, turn the left rear roller bolt counterclockwise 1/2 of a turn. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key, and run the treadmill for a few minutes. Repeat until the walking belt is centred.
9helpful
2answers
Treadmill wont run its saying waxer empty and notify maintainence
Does this treadmill have a wax system ? If it does it will have side access panels on the side just above the rear leveler. The picture that shows here does not but need to be sure it does not really need wax.
If it does not have a waxer- enter maintenance settings on display console,I do not have one in front of me but I believe you hold pause button down and press clear twice. This should bring up maintenance settings.
Scroll using up down arrow untill you see replace wax bag or something to that effect. select [enter ] to save. press clear clear to restart.
Motor control board
when we quiqestart then show on display massege commonication timeout
Top Life Fitness Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Mike Cairns
Mike Cairns
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
