Configure the Router
1. Step 1
Open your web browser, type " http://192.168.1.1/ " into the address bar and hit "Enter."
2. Step 2
Use "Admin" as the username in the pop-up box and leave the password blank.
3. Step 3
Connect to the Internet and click on "Internet Setup."
4. Step 4
Select your connection type from the drop-down menu. Choose "DHCP" for cable modems or "PPPoE" for most DSL modems. If you are unsure of these options, check with your ISP.
5. Step 5
Set a service set identifier (SSID) to identify the router and change the password.
6. Step 6
Encrypt your wireless connection using a Wireless Encryption Protocol (WEP) key. Under the "Wireless Security" option, enter a passphrase and click "Generate." This will generate a password which will need to be used by any client connecting to your router.
Note:
Resetting
the router to the factory defaults will delete any changes you have
made to the router, including any security settings. This should be used
as a last resort.
The first method involves simply pressing
a button located on the back of the router. The image below (courtesy
of Linksys) shows where the button is located.
Linksys WRT54G Reset Button Location
To reset your router, use the following steps:
