oL is an Overload error. Try running a cycle empty.
If oL (overloaded) appears in display, the load too large. If an overload is detected, the washer will drain any water and detergent in the washer. Remove several items and add HE detergent. Close lid and press START/PAUSE.
If it actually goes on and finishes the cycle and that really bothers you replace it. If not leave it alone and allow a little more time to complete its cycle. The lid switch only keeps the spin cycle from going with the top open.
If the timer hangs at points in the wash cycle, and you can manually advance, then the timer continues to run or runs shortly before hanging again, then the timer is bad and needs to be replaced.
sounds as if you have abad contact in the timer
advance the timer to a different spin cycle and see if it spins
then bo back to where it stops
if it will spin in the other spin cycles but not where it stops the the timer will need to be changed
