Contributor
- Posted on Dec 17, 2010
Re: How to configure internal LAN in B-SX4T barcode...
I hope thisis understandable.
- Switch printer off
- Whilst pressing the [FEED] and [PAUSE] keys, switch the printer on. Display shows D I A G . V 3 . 1
- Press [FEED] button 6 TIMES or until the display shows I P A D D R E S S
- Press [PAUSE]
- Press [PAUSE]. Display shows IP Address
- Using the [FEED] and [RESTART] buttons, change the 1st number in the IP address
- When you have reached the number you want, press [PAUSE] to step to the 2nd number in the IP address.
- Again Using the [FEED] and [RESTART] buttons, change the 2nd number in the IP address
- Again when you have reached the number you want, press [PAUSE] to step to the 3rd number in the IP address.
- Repeat steps 8 and 9 until you have the 4 digits you want in the IP address.
- After the 4th number has been entered and you press [PAUSE] you can change the GATEWAY IP ADDRESS.
- Step through the above sequences to get the GATEWAY IP ADDRESS you want.
- You'll then move onto the SUBNET MASK IP ADDRESS. Same steps as before.
- The next and final item is the SOCKET PORT, enter this 5 digit number as above, stepping through each of the 5 elements that make up the 5 digit number.
