Jenn-Air JED8230 Electric Cooktop Logo
Posted on May 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an old Jenn-Air cook top with down draft, approx. 20 years old. Need model No. so can order replacement for cooking elements. I have serial no. of 39060759, but nothing will match online. Would No. 2100W fit this older model? Help!
Anonymous
Level 3:
  • Master 10,865 Answers
  • Posted on May 05, 2010
Anonymous
Master
Level 3:
Answers
10865
Questions
0
Helped
3801335
Points
33142
Hello. Work directly with Jenn Air on this. Go to this link which includes a toll free number and a link to IM with their technician, for free.
http://www.jennair.com/flash.cmd?/#/page/customerservice/
. Burners will not work unless the down draft fan is turned on and then neither works at full capacity.I flipped the breaker off and on.
Call Jenn-Aire to have a technician troubleshoot your cook top on site. You will save time and aggravation whether your cook top is gas or electric, possibly wired improperly, etc,etc,etc.
I have a older Jenn air electric cook top and I need to replace the burner element on one side. How do I get the old one out and where do I find parts. JEA 800 ADB
get a gas repairer to check for you or you go back to where u bought it and the burners will be replaced or sold to you if the cooktop is still under one year warranty
How do i replace my burner on my jenn air ceramic cook top . it has the down draft feature in the centre
1) turn off power at the breaker. 2) remove hold down screws 3) pop up cooktop out of counter top 4) remove knobs and downdraft grille 5) remove ceramic top (screws around outside and also in side grille opening) 6) unplug burners replace with new burner
3answers
Spot on Jenn Air smooth cook top stove with down draft.
Use Cooktop Cleaner with a soft micro cloth. Don't use water. Buff until the mark disappears. Hint: Never clean the cooktop until it is completely cool to touch as doing so makes cleaning much harder. Never use abrasives on the glass or abrasive cast iron skillets.
3answers
Wiring problem
those wires dont go to the down draft. those colors are to hook up the stove. do you have the instalation instructions?
Both burners turn on when only one is needed
I just had the same problem- when I replaced the whole cartridge.
I repalced the infinite switch- do the one that gets the hottest- or do both.
It is easy to do- just write down the wiring diagram - make sure all power is off- cost of new switch was about $37.00
This solved the problem- however make sure to check the sizng on the new switch shaft as my old knob would not fit properly on the shaft of the new switch.
good luck
Jenn Air Not Exhausting During Grilling
is this down draft cook top or give me the m# thanks
Top Jenn-Air Cooktops Experts
Paul Carew
Paul Bade
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
