Question about Sony VAIO VGN-CR240E/B Notebook
I have sony vgn fz4000.it gets heated very soon after starting. Is there any solution
    New Friend:
  • 14 Answers
Press ctrl alt del butons together. Go to Task Manager and check if any Process is running at 100% or close to that CPU speed. This usually happens if a program or service has failed and the CPU is trying to complete the job. The CPU heating problem should be cured once you have found the program using your full CPU power. Try to uninstall that program completely. If you need it then try reinstalling again after a reboot. Read more at www.fixpcfreeze.com
Posted on May 06, 2010
6ya staff
SOURCE:
Sony Vaio Laptop Over Heating - VGN-CS26G
More than likely your cooling fans are either inoperable, or the vents for them are clogged. Take it to a reputable Electronics Shop for verification.
Oct 15, 2012 | Gateway Sony VGN-CS260TR VGN-CS260TW...
I have a sony Vaio VGN_FZ4000, after upgrading to Windows7, it says there is no camara instaled, I went to sony help but all they have are software for the camara no drivers. the camera my laptop have is...
Those 2 software packages offered by Sony on their web site, (a) ArcSoft Magic-i Visual Effects, and
(b) WebCam Companion Software, may just include the driver necessary to get their packages to
work with Win7 - pick one an install it - if the camera works, you got the driver. If the camera still
refuses to work, then all you have to do is de-install the package, install the other one and
give that a try.
The Sony drivers support page (for the Vaio VGN-FZ4000):
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGN-FZ4000®ion_id=1
May 17, 2011 | Sony VAIO VGN-CR120E Notebook
My Sony Vaio FZ4000 does not turn on after a bad bios update
Unfortunately, if a VAIO is not turning up after a failed BIOS update, the only option is to flash the original BIOS. This is only done at Sony service center.
You need to contact a Sony service center near your area. it get the BIOS flashed.
Thanks!!!!
Dec 16, 2010 | Sony VAIO FX140 Notebook
I have a sony vaio vgn nr430e laptop the display goes off as soon as the cpu fan starts rotating
That could be a problem with the heatsink/fan assembly on the processor. It sounds like the processor is starting up, getting warm as they do, the fan starts up but does not cool efficiently enough and forces a shut down due to heat.
Clean out the fan assembly and replace the old heatsink compound on the processor heat sink.
Hope that helps.
Dec 09, 2010 | Sony VAIO VGN-NR430E/S NoteBook
I have sony vaio vgn-fz31sr.It get heated very soon when I open it.when I see CPU's usage,it is normal.why?
This could be a sign that your laptop is overheating. If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
Sep 27, 2010 | Sony VAIO VGN-CR240E/B Notebook
Where would i get a new fan for my sony pcg-3cbp? as it has started making a noise?
Try cleaning it first, laptop fans **** in dust like a vacuum and it soon blocks the airflow so the fan has to work harder to keep tempertures down
May 16, 2010 | Sony VAIO VGN-AR630E Notebook
HOW TO GO TO BIOS IN VAIO VGN-FZ4000
you can go in bios with F2 this is valid for all or if you cant press Del. but be advised that if you do not know what to do you may unset something that you need.
Dec 15, 2009 | Sony VAIO VGN-CR240E/B Notebook
Sony vgn-s460: screen blinks, fan runs very loud
Possible clock timing of CPU is wrong. Is it two fan on this laptop? Maybe one is not functioning. Plus check your power supply if gives correct power!.. If none of this , it comes to the MB and possible a CAPS making problem. Need expert.
JMC
Aug 06, 2009 | Sony VAIO VGN-S460 Notebook
Sony Laptop Rechargeable Battery Driver Download
I have a SONY Vaio VGN-SZ18GP laptop ,they may use the same oem battery.Get more vgp bps2 battery information from the internet.
Feb 22, 2009 | Sony VAIO VGN-FJ290P1 Notebook
Sony VAIO VGN-CR23G Sound
i have sony vaio VGN-CR23G. i formatted this xp sp2now the sound driver is not installed on my machine. no audio output m getting........what to do..??
Sep 20, 2008 | Sony VAIO VGN-N130G/W Notebook
Sony VAIO VGN-CR240E/B Notebook Logo
251 people viewed this question
Top Sony Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
