Question about Intel Motherboard
ECS k7SOM+ 1.0 Motherboard, 1.3 AMD DURON
Is there a limit to how much additional RAM that I can add to this motherboard?
    Genius:
  • 1,027 Answers
According to the manual the board supports 1 gig of either SDRAM or DDR .
LINK
Click on the link click on USA
On page 6, I believe is the following specs.
• Two 168-pin DIMM slots for SDRAM memory modules
• Two 184-pin DIMM slots for DDR memory modules
• Support SDRAM up to 100 MHz / DDR up to 200 MHz memory bus
• Maximum installed memory is 1GB
Note: You cannot use SDRAM and DDR simultaneously.
Posted on Mar 26, 2008
3 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 13 Answers
SOURCE: I have a K7SOM Motherboard and i lost my video & sound drivers
not wory windows(xp) will have the drivers in it bank
Posted on Jun 01, 2009
Computer Links
  • 2386 Answers
SOURCE: compatible ddr memory for K7AMA Motherboard
2 DDR DIMM Sockets and 2 DIMM sockets support (can not be used simultaneously)
Two 184-pin 2.5V DDR SDRAM (DDR266/DDR200) or
Two 168-pin 3.3V SDRAM (PC133/PC100)
Maximum: 2GB
Posted on Jan 03, 2009
Maximum Ram can the Elite K755A Motherboard take?
The specifics for that motherboard can be found at the ECS website below which will detail the hardware limits for your motherboard.
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=420&CategoryID=1&MenuID=22&LanID=0
May 17, 2014 | AMD Computers & Internet
DOES K7SOM MOTHERBOARD UPGRADABLE?
Hello here is the homepage:
http://www.ecs.com.tw/ECSWebSite/Downloads/Downloads_Driver_Detail.aspx?MenuID=61&LanID=0&detailid=79#Download-2
And the + versions:
http://www.ecs.com.tw/ECSWebSite/ECSSearch.aspx?menuid=0&lanid=0&keyword=K7SOM+
I would say no because the cpu does not exist anymore.
The only thing you can upgrade is the harddrive and the ram module.
The mainboard uses SDram and DDR ram in there own seperate block.
Sdram is hard to find and expensive.
DDRram can still be bought.
The specifications:
PROCESSORS
462 pin Socket A supports the AMD K7 processors
Full series of Athlon XP/Athlon/Duron processors
CHIPSET
SiS 740 & SiS 961/962 Chipset
SiS 740 Host/Memory controller with high quality 3D graphic accelerator
SiS 961/961B/962 MuTIOL Media I/O
Integrated USB 2.0 host controller in SiS 962
LPC I/O -ITE8705F
LAN: MAC integrated in SiS 961/961B/962 and PHY on board
AC97 Audio Codec: Compliant with AC97 2.2 specification
SYSTEM BIOS
AMI 2MB Flash EEPROM
Supports Plug and Play 1.0A, AMP 1.2, Multi Boot, DMI
Support for ACPI revision 1.0 specification
MEMORY
Two 184-pin 2.5V DDR SDRAM (DDR266/200) or
Maximum: 2GB (DDR SDRAM or SDRAM)
I/O INTERFACE
Hope this was helpfull
Nov 29, 2012 | EliteGroup K7SOM Motherboard
Upgrade the 1.6GHz CPU on L7VMM2 Motherboard
ECS Support > L7VMM2 motherboard > Main Support page,
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=419&CategoryID=1&MenuID=50&LanID=0
Click on the CPU tab.
(Features / Specification / Download / Support / FAQ / CPU / etc)
Will support Up To an AMD Athlon XP 2600+,
http://en.wikipedia.org/wiki/List_of_AMD_Athlon_XP_microprocessors
Maximum Front Side Bus support is 266Megahertz.
(Max FSB = 266MHz)
(Motherboard manual states 133MHz.
Note that AMD processors are 'Double-pumped'.
This = 266MHz )
Supports AMD Athlon, AMD Athlon XP, and AMD Duron, processors.
Note in the CPU Support chart where it states -
Socket 462 > AMD Athlon XP > 2600+ (.13u)
The .13u stands for 130nm core architecture technology.
(nm = NanoMeter.
1 Billionth of a Meter )
NOTE*
For the Socket 462 (Socket A) processors, the AMD Athlon XP models are the top of the line.
'Sempy', or Sempron processors are at the bottom.
Low L2 processor memory cache compared to Athlon XP or Duron models.
http://en.wikipedia.org/wiki/List_of_AMD_Duron_microprocessors
http://en.wikipedia.org/wiki/List_of_AMD_Sempron_microprocessors
http://www.cpu-world.com/
http://www.cpu-world.com/CPUs/K7/TYPE-Athlon%20XP.html
Regards,
joecoolvette
Oct 13, 2012 | EliteGroup L7VMM2 Motherboard
Can u upgrade the processorto anything high then a amd duron(tm) 1.29ghz
On this motherboard you can use:
AMD Athlon (Highest being the Athlon 1400C running at 1.4GHz)
AMD Duron (Highest being the Duron 1800 running at 1.8GHz)
AMD Athlon XP (Highest being the Athlon XP 3200+ running at 2.3GHz)
AMD Athlon MP (Highest being the Athlon MP 2800+ running at 2.1GHz)
AMD Sempron (Highest being the Sempron 3300+ running at 2.2GHz)
Feb 25, 2011 | EliteGroup K7SOM Motherboard
What cpu can I upgrade to using my K7SOM+ motherboard? curently using AMD Athlon 1800.
Provided below is a list of all supported CPUs for you're motherboard from ECS; http://www.ecsusa.com/ECSWebSite/Support/CPU_Support_Model.aspx?detailid=316&MenuID=69&LanID=0
The highest CPU is:
AMD Athlon XP 2600+ (.13u) (256K,266,Socket 462)
Cheers'
Mike
Jan 30, 2010 | EliteGroup K7SOM (K7SOM W/CPU) Motherboard
Can I upgrade my 1Ghz processor to a faster 2 or 3Ghz? I have an EliteGroup 741GX-M, socket 462 desktop with an AMD sempron
yes, it is possible, but the Front side bus will limit the functionality so much that it wouldn't be worth it.
Jan 02, 2010 | EliteGroup MB ECS 741GX-M SIS741GX 462...
ECS K7VTA3 motherboard Will start up, but i get no video. Also what AMD processor would anybody recommend to use for this board?
well it could be your ram faulty or if it is a grapics card that could be the same but if you look at your motherboard there are 3 pins beside the cmos batary if you see the 3 pins with a jumper on it just put the jumper on to the last 2 pins for 5 seconds and put it back and fire up this will reset all your bios
Nov 13, 2009 | EliteGroup ECS Motherboard MB K7VTA3...
Planning to upgrade my RAM(motherboard K7SOM + V7.5 C
According to the specifications of you PC's motherboard. It supports DDR266 PC2100 type of RAM and only a maximum of 1gb RAM can be installed. If you have 512mb total of RAM right now, it is advisable to upgrade for a better performance of your PC.
Oct 22, 2009 | VIA ECS K7VMM+ KM266 Chipset Ultra ATA 100...
Problem in my mother board
just visit this location. it has all the drivers.
http://www.ecsusa.com/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=264&DetailName=New&DetailDesc=&CategoryID=1&MenuID=6&LanID=9
Apr 22, 2009 | EliteGroup ECS Motherboard MB K7VTA3...
Intel Motherboard Logo
963 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Ekse
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
