Have an older Venus with magic genie (model CC98KSG). When you turn it on you can hardly hear the notes played because of a constant loud noise. Is is repairable?
Find a competent repair person. You did not describe the "noise". If it is 60 cycle hum, the filter caps need replacing. If it is an organ tone, then probably a key contact is stuck.
We can only guess what model you might have and whether it is tube or solid state.
If it is a vacuum tube type, probably one tube is burned out... likely either a 12AX7 or maybe a 12AT7 as a guess.
If it is solid state and the unit has not been moved to cause a loose connector, better to call a tech. If it has been moved, you could look for a loose connector.
Try this link:http://www.organservice.com/ Here's another one:http://www.combo-organ.com/Schematics/index.htm Join this one for free and post:http://organforum.com/forums/thread/73735.aspx This site is good too:http://www.combo-organ.com/spares_and_repairs.htm#Electrolytics Hope these help.
A Leslie is special speaker system that is spun to break up the sound so it doesn't seem to come from a single point.
Sometimes the Leslie speaker is in a seperate cabinet fromthe organ, and SOMETIMES it is a simulated Leslie that is done with multiple speakers and electronic switching. If the Leslie is an external one, it usually attaches via a cable that often has either 9, 11, or 13 pins.
