Question about Mitsubishi WS-65511 65" Rear Projection Television
WS-65511 65 in. Rear Projection Television: error code 12...
Error code 12
  • 418 Answers
Error code 12 means No Error/ Normal.
Posted on May 06, 2010
6ya staff
SOURCE:
Mitsubishi WS-55311 55 In. Rear Projection Television will power on but won't stay on
When it shuts down have you tried accessing the self diagnosis feature to retreve the error code?If so whats the blink code your getting?
Feb 10, 2013 | Mitsubishi WS-55311 55" Rear Projection...
Video games projection on a Mitsubishi WS-65869
1,2 error code means NO ERROR FOUND. The set is older and may not be compatible with this set---what type of connection is being used and to which rear input?
Dec 16, 2012 | Mitsubishi WS-65869 65" Rear Projection...
Is there and error code 12 and if so what is it please and thank you.
ERROR CODE 12 IS "NORMAL OPERATION" IF THAT IS THE CODE THAT THE TV IS GIVING YOU THEN IT THINKS THERE IS NOTHING WRONG WITH ITSELF. YOU HAVE TO CHECK FOR THE ERROR CODE ONLY AFTER THE TV FAILS. TRY TO POWER ON AND IF IT DOESN'T THEN CHECK ERROR CODE.
Dec 17, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Ws-65511 error code 22 sd tech
error code 22 is an indication of a short in a low voltage power supplies
Oct 13, 2010 | Mitsubishi WS-65511 65" Rear Projection...
I'm getting an error code 32.On a WS-55859
32 isnt a valid code for your model. Mitsubishi model WS55859 has only 5 possible codes they are 12, 21, 22, 23, and 24 Double check the code again and resond to this same post and i will assist you.
Dec 04, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Ws-6580 error code 23
CODE / INDICATES
12 / No error has occured
21 / X-Ray Protect Shutdown
22 / Short Protect Shutdown
23 / Horizontal Deflection failure
24 / Vertical Deflection failure
Aug 06, 2009 | Mitsubishi WS-65809 65" Rear Projection...
What is a code 21 on a WS65809 mean? My red crt is not working.
X-Ray Protect circuit error code 21, make sure your counting it right because code 12 is no error
May 07, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi HDTV 1080 WS-55859. Error Code 12
Did you push in the device and the menu buttons at the same time and get the error code...  I have the same problem and I get a 1,2 code....   I am looking for what the codes stand for...
Have you got any help on this....
Scott
mu email is smartin38@verizon.net
Sep 11, 2008 | Mitsubishi WS-55859 55" Rear Projection...
WS 65315
ok 12 means no error detected so your set must have a standby voltage problem which is preventing the set from powering up. possibly a low voltage regulator is defective.
Aug 28, 2008 | Mitsubishi WS-65315 65" Rear Projection...
Open Questions:
See all Mitsubishi WS-65511 65" Rear Projection Television Questions
Mitsubishi WS-65511 65" Rear Projection Television Logo
330 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
