Question about Onkyo TX-DS696 Receiver
How to hook up my subwoofer
I just bought a Sony SA-WM40 subwoofer to hook up to my pioneer vsx-d912 k receiver. I'm also using 2 med/large speakers. The receiver has a sub pre out but i don't get anything from the sub when i connect the pre out to the line-level input on the sub. any advice on how to get my sub up and running??? Im using RCA L/R cable, but can upgrade to subwoofer cable if this is the problem. I'm kinda new to this stuff, so any help is appreciated. Thank you!
    Brigadier General:
  • 8,546 Answers
It sounds like you're doing everything right. Did you define the sub to the Onkyo (Subwoofer = Yes, page 22)?
Let's prove the sub works. Set its volume about half-way, cutoff= 170Hz. Temporarily connect an RCA cable from its Line Input to one of the Tape Out connectors on the Onkyo and play some FM through it. If it's alive you'll hear the low end of the music.
Don't buy into the hype that there are different pedigrees of RCA (or speaker) cables that will make an audible difference. Save your money.
Posted on May 04, 2010
    Champion:
  • 241 Answers
You need to activate Subwoofer Out in the Speaker Setup Menu on the Onkyo.
6ya staff
SOURCE:
I have a Pioneer VSX 823 - K, and when I hook up my Klipsch HG-12 300 watt subwoofer to it, the receiver is prone to overheating or just shutting off with too much bass. Is there a fix to this?
This is receiver thermal going in protect issue and has no bearing to your sub, The sub has its own power amp and not supplied by the receiver. Thermal module may be bad. See a tech.
Mar 06, 2014 | Pioneer VSX-823-K
Will a pioneer receiver vsx d309 run 2 8 ohm speakers and 1 jl audio w3
It will drive the speakers but not the subwoofer. U need to connect the subwoofer pre- output from your amplifier to another amplifier that will drive the subwoofer.
If you connect the subwoofer directly to your amplifiers speaker output it will force the subwoofer to play the entire spectrum of frequencies (not designed to do that) consequently causing damage to the sub and maybe even the amp. So use the sub pre out.
hope this helped
....andy....
Dec 29, 2013 | Pioneer Car Audio & Video
Psw111 hook up to vsx-522 subwoofer
Just use one of those jacks. Then turn the frequency select dial all the way up. This will work just as well.
Apr 21, 2013 | Yamaha 5.1-Ch. Surround Sound Home Theater...
Pioneer VSX-822-k Subwoofer problem
Go to manual setup, selct the subwoofer and set it to Pus.
Jul 29, 2012 | Pioneer Vsx-822-k 5.1-channel 3d-ready...
How to hook it up with sub dvd
Not sure what a "sub dvd' is but here's the manual. The Subwoofer Pre Out would provide a Line Level feed for a powered subwoofer, once it is configured to do so.
Page 14.
http://www.retrevo.com/support/Pioneer-VSX-D510-Receivers-manual/id/385ci969/t/2/
Jan 30, 2011 | Pioneer VSX-D510 Receiver
I have my vsx-1018ah receiver hooked up in for 7.1. Everything was fine for months. Now the back right speaker won't work. Speaker is fine, connection is good. Tried hooking up a different speaker and...
Assuming you're using the Surround Back speakers for their primary purpose, let's establish that there is something in the way of programming being routed to that speaker. Fire up the speaker level setup procedure and use any handy audio device (*) to see if a signal is present at the Surround Back Pre Out jack. If not, that speaker will never, uh, speak.
* For this test you could use your powered subwoofer. You DO have one, right? Just swap the RCA cable from Sub W Pre Out to the SB R Pre Out jack to see if anything appears there.
Jan 28, 2010 | Pioneer VSX-1018AH-K Receiver
Sub Woofer works but it won't when hooked up to the receiver
Yes, go to your menu then setup then speakers then subwoofer, it's probably in "LFE" it should give you the option of Sub, LFE, or Both. that should do the trick. Also check the crossover point and season to taste. While your at it; there should also be a setting for speaker level, toggle down to sub and adjust the sub out level, it's probably at it's minimum setting. Hope this helps
Jun 23, 2009 | Pioneer VSX-D409
Subwoofer does not work,i do not have aremotecon trol for recieve
is this the subwoofer pre out ? and is it amplified after comming out of the reciever sub pre out? also is it turned on in the surround options?
here is the manual for the vsx-d509s http://www.pioneerelectronics.com/pio/pe/vgn/images/portal/cit_11221/49515operating_instructions_VSX-D509S_20023151515575700.pdf
Dec 31, 2008 | Pioneer VSX-509 Receiver
SA-AX720 no subwoofer signal?
THIS UNIT HAS NO SUB WOOFER AMP IN IT. THE ONLY WAY TO OVER COME THIS IS TO HOOK THE LEFT AND RIGHT FRONT SPEAKERS STRAIGHT TO THE SUB WOOFER AND THEN GO FROM THE SUB WOOFER BACK TO THE INPUTS ON THE BACK OF THE UNIT FOR THE FRONT SPEAKERS. THE SUB WOOFER THIS WAY WILL EXTRACT THE BASS AND THE FRONT WILL RECEIVE THEIR PART. THIS SOUNDS CRAZY AS HELL I KNOW BUT THAT'S HOW I GOT MINE TO WORK. THE OUTPUT FOR THE SUBWOOFER IS USELESS AND PUT THERE FOR YOU TO HOOK UP AN AMP FOR A SUB WOOFER. EVERYTHING HAS SHORT COMINGS, AND THAT'S THE ONE FOR THE AX-720.
Sep 22, 2008 | Technics SA-AX720 Receiver
Onkyo TX-DS696 Receiver Logo
580 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
