Just 3 months old, worked just fine and then stopped, checked all of car fuses and all looks fine, it appears the problem may be the receiver...any suggestions?
Could be internal fuse of the receiver. Or the internal capacitor or power supply is bad. Further testing with an ohmmeter and internal access would be needed.
Hello. If you are sure that the fuses are all good, including the fuse in the base of the plug that goes into the cigarette lighter socket, then return the radio. It is under warranty. Joe
Try and look on the back of the receiver or on the front for a reset button might be a small pinhole somewhere try that and see if it works my friend had a similar problem that was resolved by resetting the unit
Sounds to me like a switch problem The master window switch should be checked. Also check the door switches to see if they are getting voltage. Could also be bad window motors. Tests need to be done. Is there power to the power seat switch?
I checked the fuse and it looked OK, however working on a hunch I decided to replace the fuse anyway. This immediately addressed the problem and my Fishfinder is now working again.
check the breaker i know the washer works so how come the dryer works on 220volts if one side is out the washer will work but not the dryer if that is not it check the door switch the unit also has a thermal fuse that could be out there is no reset button
The foldover is because of a bad capacitor in the vertical circuit. Given the "new" sympotom of a dead set, I would suspect that the vertical IC has failed. This should be a relatively simple repair for a TV shop. If you wish to attempt a repair of this yourself, update this and confirm your model number and I'll post more details and instructions.
sirius model st5
