Hi rmu_jaan,
Based on your concern, I suggest trying the following steps:
1. You can download the audio driver here:
--> this audio driver is compatible with windows xp.
2. After downloading, install the audio driver then restart your computer
Hope it helps,
Thank you for using FixYa.
Hi.
Install this driver: Conexant Audio Driver.
If that does not install automatically, go to device manager right click on the audio device and choose to install the driver maually.
Choose 'have disk' and browse to find the driver. It is probably in C:\Drivers\Conexant Audio Driver\XP32 .
Follow instructions here: How to install drivers in windows XP | eHow.com
At point 7 choose "Don't Search I know the driver location" then choose "install from a specific location", then choose "have disk" and browse to locate the driver downloaded from link above. If the driver does not show up, untick "Show only compatible hardware"
Regards.
Just go to folowing sit you will get you audio Drivers
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=CONS-SUPPRT
SOURCE: how to install xp in lenovo g550, its cant able
fist go bios & give boot from cd RAM save it exit from there insert XP CD it will ask you press any key ,just pess it then it will start coping fails & drivers after that XP will install ok
Do you have the driver already and just need help to install it? Or do you also need the driver and how to instll it?
