Question about OKI B6300 Laser Printer
CHANGE PAPER TRAY DRAW
MISPLACED OWNERS MANUAL. PRINTER DRAWS FROM SMALLER PAPER TRAY A, WOULD LIKE TO DRAW FROM LARGER CAPACITY TRAY B. PLEASE ADVISE.
    Habit-Forming:
    New Friend:
  • 62 Answers
Face any technical issue your printer so don't worry call Us @@1-8@77-##7@7#8-%%8#9#6#9@@ toll free 24*7. For more info visit Us:
http://callpcexpert.com/okidata-printer-support.php
Posted on Apr 18, 2017
    Scholar:
  • 67 Answers
You will need to specify your choice as the "default" tray. You can do this either by scrolloing through the Menus on the printer, or by making the change in the printer's driver on your PC.
You should also be able to get the user manual for free from Oki online. Look for "Drivers, Support, Downloads" etc. Should not be hard to find.
Posted on May 03, 2010
  • 466 Answers
You may find a suitable manual here:
http://www.retrevo.com/support/Oki-B6300-Printers-manual/id/1304dj983/t/2/
Also, the tech manual is here:
http://my.okidata.com/tech-b6200-b6300.nsf/MOCContents/377DAE221B3535AF85256EE8006B0F59?OpenDocument
Anonymous
SOURCE:
C 0204 error
is there paper behind the draws/ remove it. Remove the paper from the left side of the paper draw IT IS NOT A STORAGE AREA its for 11x17 paper. If not then bad tray lift motor or worse case control board$$$$$$$$$$$$$$$$$
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 28, 2014 | Konica Minolta bizhub C450P Laser Printer
How to fix ? the tray 1 tray 2 appear question mark on bizhub 750
That indicates the copier does not under stand the paper size in those draws so check the guide that hold the paper. ensure they are snug up against the paper also check that there is no paper stuck behind those draw preventing the sensors from reading the correct paper size.
Apr 28, 2014 | Konica Minolta Office Equipment & Supplies
C0910 konica di3510
The 2nd Tray Lift motor. Remove draw #2 and check to make sure no paper behind the draw. Secondly REMOVE THE ETRA PAPER IN THE DRAW THE EXTRA SPACE IS NOT FOR SPARE PAPER, it for if you are going to put 11x17 paper in the draw. If these don't work you mite have a burned out 2 tray lift motor. When you close the draw that metal plate at the bottom of the draws goes up
Dec 18, 2013 | Minolta DI-2010F Copier
Minolta ep 4000 how to disable the third paper tray
If the 3rd paper tray is LCT (large capacity tray) disconnect the tray electrical connector on the rear side,or not close the tray.
Feb 27, 2013 | Minolta EP4000/5000 CS/PRO Copier
Minolta di 251 error code c133a
Electrical disconnect Draws #2 draw #3 draw #4 and Draw #5 all connections for each of those draws is in the rear middle cover. Also remove the job tray that the device where the paper comes out for faxes print etc. leave only draw one connected power off the machine turn back on after ten seconds. if the code is gone have a bad draw (s) if it comes back replace the main board if you can find one. The Di251 is legacy machine Minolta is now Konicaminolta. If the code did not come back your going to start connecting each draw back one at a time. Fig out which one(s) is causing the problem
Feb 06, 2013 | Minolta DiALTA DI2510F All-In-One Laser...
I don't have a owners manuknow how to change the paper trays from
Go to Menu, then Paper Menu. Select Paper Source then select Manual Feeder. You should also select manual feeder from the driver.
I'd like to add the link to download the User's Guide for future reference. http://www.lexmark.com/publications/pdfs/optram410/enUser.pdf. Hope this helps. Leave a comment if you need more assistance. Thanks.
Jun 29, 2010 | Lexmark Optra M412 Laser Printer
How to print with the legal paper?
follw the given step and check-
1-Before printing your document, be sure the page size is set to legal paper. Go to "File> Page Setup" and then click on the "Paper Size" tab. Select "Legal" from the drop-down menu.
2-Go to the printer and take out the paper tray. Remove the letter size paper.
3-Insert about one half of the package of legal size paper into the tray, depending on the depth of your tray. Larger printers can accept an entire package, while smaller ones cannot.
4-Make sure that the paper goes underneath the metal clips located at both the front and back of the tray.
5-For printers that don't have a tray, you'll have to manually feed the legal size paper. Locate the paper feed either on the front or rear of the printer.
6-Put a few sheets of legal size paper into the paper feed. The paper should be placed as close to the rubber spindles as possible. These spindles will draw the paper into the machine and feed it through the printer.
7-Print a test page.
Thanks,
Dec 03, 2009 | Brother HL-2040 Laser Printer
Close drawer...
Take paper draw out of the machine you mite have paper behind the draw preventing sensor monitoring that draw from working properly. Mite get some can air an get any paper dust off the sensor for that draw. Is paper properly installed and are the paper guides securing the paper properly installed? Don't be storing additional paper in the draws. Is paper in the draw matching what is on the operators panel.
Aug 15, 2009 | Toshiba 2060 Copier
C0910 code im3520 imagistics copier
Your lift motor, for second paper tray draw, or third draw, are you storing extra paper in the second or third draw, beside the paper properly placed in the draw. Is there paper behind the draw? Do not store extra paper in a paper draw. Just because the draw has space not setup for 11x17 paper and is being used for 81/2x11 dont store extra paper. If this is a large capacity tray for over 500 sheets paper can only be set up for 81/2x11 protrait not landscape.
Aug 06, 2009 | Office Equipment & Supplies
Tray 1 Low
How many input trays does this printer have?
Trays can be renumbered to allow for larger capacity input trays.
Please print out the menu setting pages and verify the correct paper tray numbers.
Don
May 15, 2009 | IBM Infoprint 1532 Laser Printer
OKI B6300 Laser Printer Logo
434 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Thomas F. Schneider
Ekse
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
