Brother CS-8060 Computerized Sewing Machine Logo
Posted on May 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
AUTO THREADER CAME OUT
When i was needling the thread the needle was down and the auto threader just got of from its place...now i cant needle the thread as the threader has come out and i can do it manually
Anonymous
Level 3:
Genius:
  • Master 1,116 Answers
  • Posted on May 01, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1116
Questions
0
Helped
371624
Points
3174
When you activated the threader, the needle was down and the threader came off or broke.
If it is not broken, you may be able to push it back into place.
Turn off the power and tip the machine back on some towels so it does not slip and with a flash light check the area where it fits and see if you can get it back into position.
If not, will have to thread the needle the old fashion way.
Check with your Brother dealer to see if they can look at the machine while you wait.
They may be able to get it back together or they will have to replace the threader.
It is possible they will have one in stock, or they may have to order it.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 24, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1051
Points
Auto threader it dont do automatic threader and something fell on it i dont have no idea a parts that came out, since then is not doing automatic to thread the needle.
2answers
The automatic threader wont pick up and thread needle. Can do manually but thats not easy?
to make manual threading of a needle easy buy a needle threader
it is a instrument that has a very fine piece of wire in a loop that you push through the eye of the needle , put the thread in that loop and pull the loop back out of the eye and the needle is threaded
available from most any shop that sells material , cotton , thread or sewing machine shops
cost --pack of 2 for $1.00 or there abouts
Auto threader wont thread
Move the needle to the top.
Loosen the screw on the threader.
Use the threader as if you are using it. You will have to adjust it to the side and up or down. Move it so the threader is in the needle hole.
Tighten the needle.
If it still doesn't work you may need to replace the threader.
Automatic needle threader stuck
You may have a thread stuck in your bobbin area. Remove your bobbin, brush gently with a clean soft brush to remove dust and/or thread bits, then gently wiggle your hand wheel back and forth, and brush again. This should free up your machine.
Difficult to use auto needle threading
you thread the machine the normal way, using every thread guide, and if the automatic theader works it will thread the needle,
if the auto threader doesn't work, then it needs to be checked.
also make sure the needle is turned the correct way and inserted correctly into the needle holder.
Auto Needle Threader Won't Come Down
If it's still in warranty, send it in for repair. If it's not still in warranty, pull out a length of top thread and clip off the end with sharp scissors at an angle. Poke the end of the thread through the needle eye -- it should go through easily. Two second solution.
Cant make the auto threader work on an elna 2007
Do you mean the auto needle threader?
Mine won't work on very small needle sizes so I resort to the old manual needle threader for these. Ditto for twin needles.
Otherwise its a case of pulling the auto threader down so the hook swings into the needle eye, then pulling the thread over the face of the needle and catching it into the hook, then release the threader so it pulls back through the needle eye, taking the thread with it.
The only other thing that springs to mind is "is the needle at the top position in its stich cycle so that the threader lines up with the needle eye?
hope these ideas help a little.
How do I theard the needle on the 5050C singer machine?
does the machine have a needle threader? first if so, pull it down and put the thread behind the left side of the threader and loop the thread around toward the needle then go behind the finger of the threader hold the thread back against the needle and slightly pull upwards pull the threader forward and gently let go with the right hand of the thread and the needle will pull the thread through, second if the machine doesn't have a threader, the easiest way to thread a needle is to buy a needle threader, it is a device that you put through the eye of the needle and put the thread through its hole then just pull the threader back out and the needle is threaded.
3helpful
2answers
Janome MC 10001 auto. needle threader stuck in up position.
You are threading the top of the machine incorrectly.
Make sure the needle is in correctly with the flat side to the rear of the machine, make sure to thread the upper and lower portions of the machine correctly. If this does not solve your problem, please respond.
2answers
I can't thread the Shark Euro0pro 384 unng the automatic threader
You need to check to see that there is a small hook going through the eye of the needle when you use the threader. A flashlight or bright light will help. So will a magnifying glass. If it isn't, then no amount of trying will help.
If it goes through the eye, you need to see that your thread hooks into it so that the thread can be pulled through.
sewman7
Automatic Threader Never works
lever the auto threader slightly back and pull down- if it doesnt pull down adjust the needle up or down slightly. Once it is down behind the needle, place thread under far left of threader then pull across to far right and hook behind tiny hook. Sounds complicated but not so when you get the basic action. Release and guide back up and the thread should be thru the hole and looped up bahind it. Hope you get it.
Top Brother Sewing Machines Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
