When am trying to install new themes, am getting an error saying that ' Installation Security Error. Unable to Install'.
There could be a number of reasons, the most likely is the phone being overfull with data old, new and unnecessary files.
The phone needs a certain amount of memory to function. Also make sure the themes are for the Nokia N70.
Go to www.ownskin.com and try their themes or make your own.
The security on install should be ignored, (at your risks). Most companies don't bother with the security certificate.
TO MANY FUCKEN IDIOT BOLONEY HERE....
In NOKIA N70:
1. Go to: MENU>>TOOLS>>MANAGER>> then on the TOP you gonna see: " Application manager " UNDER THE APPLICATION MANAGER you gonna see: " Application downloads " AND UNDER THE application downloads you gonna see some THEME name ( example: Glass_Apple_b...)you downloaded from your PC to your NOKIA N70 before nut could not installed, because you got the message: "Installation Security Error".
And now: go to the THEME ( example: Glass_Apple_b...) and then left side you gonna see: OPTIONS, click to the OPTIONS.
And now go to SETTINGS, and go to: Software Isntallation and THICK FOR: ON,
"Online certif. check" THICK: Off.
GONE...now you can install any NOKIA N70 Themes, and do not cry anymore:))) ********:))
unable to install software, security error problem
hi my problem is somewhat related to this one When i tried to install new themes, i got an error saying that ' Installation Security Error. Unable to Install'. then a pop up message " cancel try again or continue, i hit cancel, it keeps on popping, and then i tried to save pictures from my computer it says " disk is write protected, pls remove write protection from ur memory card" i dont know what to do, pls help me
i downloaded programme to my phone n70, but when i tryed to install it the (installation security error unable to install)
Amer
when i try to install anything, it says unable to install. My software installion settings is on,
Go tools----> manger------>setting....>softwere instalation yes
