1. Why hisense TV red flashing power light has sound but no picture
There could be a few reasons why your Hisense TV has a red flashing power light but no picture. It could be an issue with the TV itself, the power supply, or the input signal. Let's take a look at each of these possibilities in turn.
2. How to fix hisense TV red flashing power light has sound but no picture
If your Hisense TV has a red flashing power light but no picture, there are a few things you can try to fix the problem. First, check to make sure that the power supply is plugged in and that the TV is receiving power.
Next, check the input signal to make sure that it is compatible with the TV. Finally, if the TV itself appears to be the problem, you can try resetting it.
3. What to do if hisense TV red flashing power light has sound but no picture
The problem might come from the fuse inside was blow out. if you have a multimeter then open the rear cover. The fuse lays near the power cord. Take it out and use Ohm meter to check it connectivity. If it is no connectivity meaning the fuse was blow out. Replace a new one with the same value (Ampere and Voltage). If it does have connectivity, the problem needs technician to find out as it relates to many parts on the circuit board.
