This is in response to the answer you provided, i do not have the cables mixed up maybe i didnt explain my problem correctly. the problem is that my subwoofer doesnt play even when i go to the pc lay out and click on the appropriate speaker they all play when i click on the sub i get no sound at all.
It looks like you have posted this before. Unfortunately, I don't know what you have tried so I may be repeating some of your earlier troubleshooting.
The subwoofer needs its own power supply to function properly. if it isn't getting enough power, the sub will not work at all.
On the back of the unit, you should see a green LED when the power is turned on. Is this light on all of the time of does it fade / flicker? This would indicate the power supply is going bad and you need to replace it.
It seems like you've tried various connections and settings to get your JBL135 subwoofer working with your Kenwood receiver, but you're still facing issues. Let's break down the situation and provide some recommendations:
Subwoofer Connection:
Using the LFE/Subwoofer Out: This is the preferred method for connecting a subwoofer. Ensure that the cable is firmly connected to both the subwoofer's LFE input and the receiver's Subwoofer Out port. Make sure you have enabled the subwoofer output in the receiver's settings menu.
Subwoofer Settings:
Gain: Adjust the gain knob on the subwoofer to achieve the desired bass level. Experiment with different settings to find the right balance.
Crossover: Set the crossover frequency on the subwoofer to blend with your tower speakers. Start with a conservative setting, such as 80Hz, and adjust as needed.
Receiver Settings:
Speaker Configuration: Set your tower speakers to "Small" in the receiver's settings menu to redirect bass frequencies to the subwoofer. This ensures that the tower speakers are not trying to reproduce deep bass.
Bass Management: Enable the appropriate bass management settings in the receiver's menu, which typically includes crossover frequency and speaker size adjustments.
Check Subwoofer Cable and Port:
Ensure that the subwoofer cable is in good condition and securely connected to both the subwoofer and receiver.
Try using a different cable or testing the subwoofer with another receiver if possible to rule out cable or port issues.
Factory Reset:
If you've exhausted all troubleshooting steps, you may consider performing a factory reset on your Kenwood receiver. This will reset all settings to their default values, potentially resolving any configuration issues.
If none of the above suggestions work, it's advisable to consult the user manual for your specific Kenwood receiver model or contact Kenwood customer support for further assistance. They can provide more detailed guidance based on your equipment and setup.
no you need the ribbon this connects the all together to get the sound usless with it get in touch with sony tell them what you haver they usuall have spare parts they will send you a new one, worth a try if not ebay is the answer
"CAUTION: Make no modifications to the system or accessories. Unauthorized alterations may compromise safety, regulatory compliance, and system performance."
That warning is not in the manual to just protect their market share. Even if you succeed in making the desired electrical connections the results may be less than stellar.
I'm not saying this IS the case but here is some Food for thought.
Bose's main claim to fame, the 901, was always based on achieving flat audio response from full-range speakers (NO WOOFERS or TWEETERS in the case of 901's) through the use of large amounts of prioprietary equalization applied to the audio signal. Another evolutionary step way in Bose amp/speaker systems was to deviate, sometimes drastically, from the 8-ohm speaker driver standard and design the mated amp to work with the selected load. THAT is just two reasons why no specs are published for the sub-parts of any BOSE SYSTEM. It's a system.
In the mix n match world of COMPONENTS specs are published so one can choose a given speaker for use with a given amp and expect electrical compatibility, frequency response and power handling.
Except for standalone passive speaker systems, mixing and matching Bose speakers with third party electronics (or vice versa) is discouraged as being potentially dangerous and at the least sonically unwise. For example, if you've ever heard how a Bose 901 Active Equalizer sounds with non-Bose 901 speakers you'd understand.
Maybe someone else can fill in the pin-outs of the cable and chime in on whether or not Brand X speakers will work with the Cinemate amps. Not knowing what other brand/model you're contemplating, it would be impossible for anyone to offer a qualified judment on that score.
If you identified the specific products involved we (and you) might be able to look at the documentation and verify the obvious answer. Voice is generally concentrated on the center channel, so, yes, a speaker there would be a good idea.
If you don't have a multi-channel rig you shouldn't feed multichannel audio to it. Maybe use the unidentified DVD player's analog output and make sure it's set to mix the channels down to stereo.
Usually the "low frequency driver"is the speaker that is responsible for playing the lower frequencies of the audio. Otherwise is the speaker that is in the subwoofer, or the woofer at the 2-way speakers. Do you came up with a problem with your own subwoofer or you are just asking a question?
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer. If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards Please kindly rate this solution Stelios direct FixYa link: http://www.fixya.com/users/technical114
Hi all, I also purchased a logitech x-540 a few days ago and also have
the center speaker outputting sound when i test or play the subwoofer.
I didn't think this is normal and am now confused. Maybe its a problem
with the audio drivers? MB is a ASUS P6T Deluxe V2 with Soundmax
drivers. Hopefully someone can help to diagnose/ find a soluytion.
HDMI input connect as follows: 1.Connect an HDMI cable from the Cable box to the TV/CBL HDMI input on the Denon. 2.Connect an HDMI cable from the Xbox to the DVD/HDP input on the Denon. 3.Connect an HDMI cable from the HDMI out-put on the Denon to an input on the Samsung. You don’t have to use the optical output from these to devices since the HDMI cable allows for the transfer of both audio and video, if you have them extra use them in addition tothe HDMI cable and last, 4.On front of denon after you setup and assign your optical connections, if you use them, once you select TV/CBL or DVD/HDP as a source, press the input mode button to select auto
