SOURCE: Connected on Wireless but unable to connect on Internet
If not done allready, setup the lan IP address and default gateway in win98 Click MyComputer-ControlPanel-Network-Double Click TCP/IP Adapter for your 3com device-insert LAN info for IP Adress-subnet mask, Gateway and your Internet service providors DNS Addresses info Tab's (3x different Tabs "IP Adress" "Gateway" "DNS Configuration") IP Adress will be at least one number higher than your gateway address and not allready being used by other PC's on your network and gateway address will same as your router interface address subnet mask will be the same for all PC's on your network. For 3com and Netgear routers LAN setup is usually Gateway = 192.168.1.1 Subnet Mask = 255.255.255.0 IP Adress = 192.168.1.10(choose alternate number than 10 if allready used by another PC on your network, try to use round numbers, must be a number higher than 1) Once all info is entered click OK (this may trigger a database info update message and task)now your LAN is setup and ready to talk to your network Restart PC and try browsing again. May possibly require reinstallation of the TCP/IP client (you double clicked this to setup your LAN in Win98) or reinstallation of the IIS(Internet Information Services)component found in, Add/Remove Programs-Add/Remove windows components and then try LAN setup again if this does not work first time round
SOURCE: wireless routers
Just plug the cable modem ethernet into the input to your router and you will be fine. Just remember, if you decide you want to make any changes to your router settings through your browser, make sure you hook up an ethernet line from your laptop to the router before making any changes. The reason for this is if you make a change in security settings on your router while wireless, the router will reboot and if your laptop did have the settings changed in it, you can be locked out.
Not that you can't get back in, but it is a pain to have to do.
SOURCE: Wi Fi fine, ISP fine, no internet via LAN connection though.
Make sure your firewall is not blocking your ability to go to websites. I saw this the other day, somehow the users firewall was set to block all internet traffic out of the computer.
SOURCE: wireless internet connection
I may be able to help with this...but I need a detailed description of how you have things connected between the XP desktop, the cable, modem, the Linksys router, and the laptop. Also, is the Linksys router new?
Typically, the wan port on the wireless router connects directly to the cable modem with a cat5 network cable....then the desktop pc connects to the router...on port 1 for example...with a similar cable. Once the wireless router is set up properly, the laptop should then be able to connect using wireless.
SOURCE: RE: DSL 302G WINDOWS VISTA
Try the following forum - it works!
http://forums.whirlpool.net.au/forum-replies.cfm?t=716454#r2
