KitchenAid KGST307 Gas Kitchen Range Logo
Bill Bensinger Posted on Apr 30, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Stove top burner ignitors will not turn off
This happened after a liquid spill on the stove, all 4 burner ignitors spark continuously even though the burner controld are off. stops when you pull the electric plug. Is there something that needs to dry out, will heating up the oven help this ?
Anonymous
Level 3:
  • KitchenAid Master 43,501 Answers
  • Posted on May 04, 2010
Anonymous
KitchenAid Master
Level 3:
Answers
43501
Questions
0
Helped
10835353
Points
101584
This tip I wrote to help people with the problem of the spark not shutting off...the clicking non-stop is a common problem.
Gas Rangestove top burner ignitors will not turn off - 2_bing.gif Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
1helpful
Burners light but ignition keeps clicking
use a blow drier to dry the igniter and knobs.
Kitchenaid superba oven
It is very possible that moisture from the cleaning has caused the ignition switches to make enough resistance to cause the burners to spark. It usually goes away after the stove has dried out. If it continues after a day or so one or more of the ignitor switches may need replacing.
Nov 20, 2013 • Ovens
6helpful
All 4 igniters keep clicking, when one is on
All of the igniters are connected to one source. A series of small switches mount on each stem of each burner. Any of them can fire up the spark box and it in turn it fires off all the ignitors. If a boil over spills liquid into one or more of them switches the resulting continuity causes the clicking. Removing one wire at a time from each switch till the clicking stops is the solution.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
1helpful
Stove Ignitor makes tik tik sound and the sparks continuously
may be a loose wire on the spark ignitor ceramic or if you run via main electic it may be your spark generator
GE Profile igniter sparking continuously after water spill
The continuous sparking stopped after few hours. Looks like the water dry up and that fixed the issue.
Ignitors keep firing by themselves after my aunt cleaned them 24 hours ago After she did the major cleaning of the stove I used the oven and it worked fine. I lit a burner (Probably front?) and the left...
Apparently there was a water spill around the burner control knob and in the burner itself; We ran the burner to create heat and then turned it off and let the water dry out and evaporate from the burner and igniter area.
5helpful
3answers
Ignition sparking repeatedly
I have a Creda gas stove ,yesterday some water boiled over. I have a continuous spark ever since and the stove is not even on. Is there any way to reslove this without calling a repair person?
May 01, 2008 • Cooktops
3answers
Igniter continuously clicks
I had this problem. It was caused by the burner "thinking" the flame had turned off--it was clicking because it was sparking to re-start the flame from the gas. I was able to fix it by tightening a flat, thin nut at the top of the burner.
Top KitchenAid Kitchen Ranges Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
vince
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
