I have a printer plugged (via usb port) into my desktop pc (running xp professional) and wirelessly connected to my laptop (running vista home premium) via a home network. It has been working just fine until this morning. I tried to print a .pdf file and it appears as though it is being sent to the printer but when I went into the other room to get the files the printer had not printed them. The printer did print .pdf files on Wednesday which was the last time I had the pc or printer turned on. What has happened and how do I fix this problem? Nothing has been changed on either machine since I used it last on Wednesday. (the printer will print the .pdf file if I copy it to the desktop machine and then try to print it.)
The printer is printing regular word documents with no problems.
SOURCE: Does not print pdf files
It sounds like it is a printer memory issue. That printer comes with just 64MB of memory and PDF files are complicated for most printers. Try printing a few pages at a time for that PDF file and see if that works. If so than it is a memory issue.
SOURCE: HP C6180 Print Queue Error
click start, click on network, when you see the printer on the network, right click the printer and copy the IP address shown there.
click start, click on printers, right click the printer, click on properties, past the ip address into the location bar, then clikc on ports and make sure the correct IP address is check marked, if not add the corrent one using the add port button,
SOURCE: Can't print to 1410 after I upgraded to Leopard
I believe I had a similar problem. Try this:
Go to System Preferences > Print & Fax > '+'
Select the Epson 1410 and then under Print Using go to Select a driver to use the Epson Styls Phot 1410 - Gutenprint v5.1.3
I hope it helps.
Try a complete uninstall:
Unplug the USB cable from your PC.
Go to Control panel add or remove programs. and delete all the entries you see for HP.( If it promts a restart do not restart now)
Then open my computer> C:drive> Program files> and delete the HP Folder only (not Hewlett Packard)
Then Open C:drive> Program files> Common Files and then delete HP and Hewlett Packard folder.
Then Go to C:Drive> Windows> Temp and empty the temp folder as much as you can.
Then go to Recycle bin and empty recycle bin.
Then Insert the All-In-One CD and cancel the installation process.
Open the content of the CD> and open Util folder> Then CCC> Then click on Uninstall_L4 and follow the on screen process.
After all restart the computer.
And if possible download the latest printer driver from HP website and install the same
Let me Know if any problem
Good Luck
