Have philippe starck with fossil ph-2006 lost instructions can't set anything.
can you help e-mail [email protected]
Hold the left, bottom button (marked ....) for a few seconds....then press the top right button (marked with 1 dot) to change between the hour, minute, date etc. use the bottom right button to advance the flashing number, and when finished setting time and date, use the bottom left button to stop the numbers flashing and return the watch to normal. hope this helps, this is also how to change the date for the other question asker (works on 2 other starck/fossil watches i have and i assume the controls are the same).
Hey there
you have a very nice wrist watch!
there is no online support on hot to set your fossil wrist watch so i advice you to contect there support
1-800-842-8621
or email [email protected]
hopefully youll get the solution for your problem.
thanks for using fixya
Fossil Contact Information Main support number 1-800-842-8621
Email support [email protected]
hope this helps
no movement after battery change
