2004 Jaguar X-Type Logo
Posted on Apr 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
List items for service at 5 year service interval
blustu
Level 2:
  • Jaguar Expert 279 Answers
  • Posted on May 02, 2010
blustu
Jaguar Expert
Level 2:
Answers
279
Questions
Helped
174912
Points
437
Maintenance must be carried out at 16 000 km (10 000 miles) or 12-monthly intervals from date of delivery, whichever comes first.
Renew engine oil and oil filter.
Renew drain plug sealing washer.
Renew drain plug assembly.
Visually check underbonnet/underbody
for any fluid leaks.
Inspect brake pads for wear (brake disc
condition on pad change).
Renew coolant.
Renew spark plugs (Normally Aspirated). 112 000 km (70 000 miles)
Renew spark plugs (leaded fuel markets only).
Check accessory drive belt tension wear indicator(s) – replace belt(s) if necessary.
Renew front accessory drive belt. 160 000 km (100 000 miles)
Renew rear accessory drive belt. 112 000 km (70 000 miles)
Check/top-up brake fluid level.
Check/top-up coolant level.
Check/top-up windshield washer reservoir.
Check/top-up power steering fluid level.
Check/top-up battery electrolyte level.
kingtwomp
Level 2:
New Friend:
  • Expert 161 Answers
  • Posted on Apr 29, 2010
kingtwomp
Expert
Level 2:
New Friend:
Answers
161
Questions
Helped
43483
Points
390
Usually you go by the miles on the vehicle and not the years. At 5 years I would definitely make sure to check out all the hoses. I've found on newer cars the rubber tubes and plastic connectors seem to get brittle and break down around the 5 year mark.
What gets done at 60 000 service intervals for petrol engines
This is best answered by the service schedule of the car. Any car of the same make around the year of manufacture will have the same schedule. IF it is miles you are referring to then items like cam belt change, auto oil change, brake fluid change, coolant change brake rotor check, cv joints would most likely be on the schedule as 60.000 miles is a big service.
What is the cost for a tune up
Cars don't require a tune up like they did 20 yrs ago. There is a list of recommended service items found in the owners manual for mileage intervals.
At 100k I would say the filters and spark plugs should be replaced, along with the trans fluid and several things inspected. Prices would vary depending on where you live, so check with some local shops.
1helpful
I changed oil how do i make the maintenance grid recognize it
You must manually reset the system
BMW Oil Service reset for 2001 ~ current model year
- Ignition OFF (POS 0)
- Press and Hold the trip odometer button while turning key to position 1 (ACCESSORY)
- Keep the button depressed (about 5 secs.) until you see "Oil Service" or "Inspection" with "Reset" or "Re" in the display
- *Note: On vehicles with "High" cluster, you will also see the amount of fuel (in litres) remaining until next service
- Press the button again and hold for approx. 5 secs. until "Reset" or "Re" flashes
- While the display is flashing, briefly press the button again to reset the Service Interval. After the display has shown the new interval you should see "END SIA" for about 2 secs.
Note that if the "Reset" or "Re" does not flash, then you have not met the minimum consumption level and cannot reset
Sep 06, 2012 • 2005 BMW X5
Can I reset the idrive on my BMW 645 as it works for a couple of weeks and then stops ?
Well you may follow the step below to reset idrive -
Firstly with the ignition switched on, set the odometer trip meter back to zero by pushing it once. Then switch the ignition back off again.
1. Switch the ignition on so that the battery, Oil and Parking brake lights are displayed and the key is ready to start the engine, but note you don't actually start the car.
2. Press the odometer reset button for between 5 and 10 seconds until a yellow triangle with an exclamation mark in the center appears in the top window between the clocks (where the outside temperature / time or date normally appears) - this is the "Service" icon.
3. Release the odometer button briefly and press again straight away which brings up a picture of the Brake Fluid symbol (same as the one that the i-drive shows when you look at the Service menu).
4. If you want to reset the Brake Fluid interval for another 2 years then keep holding the odometer button until the word "RESET?" appears at the bottom of the lower window.
5. Release the button briefly and push it in again and hold for about 5 - 10 seconds until the new date appears in the bottom window. You can then switch the ignition off and the new Brake Fluid date will appear in the service menu on the i-drive screen next time you switch on.
6. If you want to reset the Oil, Microfilter or Brake Pad indicators then you will need to follow the same sequence as steps 1 and 2 above, but when you get to step 3 and the brake Fluid icon appears, just release the button and press again and the next service item will appear.
7. You can continue releasing and pressing the button until the required service item icon appears for the one you want to reset. As soon as it does then hold in the button in until the word "RESET?" appears again as in step 4 above. Once the word "RESET?" has appeared, you need to release the button briefly and hold it in again for about 5 - 10 seconds until it is replaced by the new service interval figure (as per step 5 above). hope this helps...
Good Luck
Regards
Maintenance reset button, how to turn it off?
NOTE: If the service interval indicator flashes it may be caused by one of the service interval indicator parameters not being programmed. This can only be done with suitable diagnostic equipment. Always check for any stored trouble codes as this may affect the resetting of the service interval indicator.
Turn ignition key to position I. Press and hold reset button [A] 20573 for trip meter. Turn ignition key to position II. Keep button [A] depressed until service interval indicator flashes (approximately 10 seconds). Release reset button [A] within 5 seconds. There will be an audible signal when reset complete. If reset button is not released within 5 seconds, the service interval indicator will not be reset but will stop flashing.
What is service intervals for Toyota Corrola 121 nze
oil/filter 10k. main service/filters.20k.plugs 40k timing belt60k.or annually as above.oil is 5/40 semi synthetic to 50k then10/40 to 100k,then 20/50 thereafter.following this regime you car will last years..........
If you have an 1988 old car and you wana keep it for as long as possible what things should be taken care of or changed over the years to run the car at its best
Keep a very close eye on your regular service items, trans fluid flushes, oil changes, and flush your other fluids as well, ie... brake and coolant.A very important item is to replace your timing belt at the specified intervals or it could fail and cause massaive internal engine damage.Hope I could help!!!
7helpful
4answers
Should a 2005 Taurus with 100,000 miles have the water pump replaced as preventative maintenance? What about the timing chain/belt?
Yes it needs to be replaced its already time for that.
IntervalsHere is what I recommend for maintenance intervals. There are exceptions to all of these including severe duty, which most northern cars fall into.
  • Change Transmission filter-30,000 miles, 90,000 and 150,000 miles and fluid at 60,000, 120,000 and 180,000 miles.
  • Change oil every 3,000 miles or 3 months, unless you use Mobil One, in which case 6 months/6,000 miles.
  • Chassis lube every 3,000 miles, assuming there are fittings.
  • Spark plugs: Conventional plugs: 30,000 miles, Double platinum: every 50,000 miles (100,000 mile plugs are best to be changed well before that, although some can reach it).
  • Fuel filter: 35,000-40,000 miles. Unless it is in the tank. But if the tank is ever dropped, do it then
  • Ignition cap, rotor, wires: 60,000-80,000 miles. (if it has them).
  • Timing Belt, if applicible: 60,000 miles on many but check with gates or dayco or the manual or dealer, as many different intervals are now present.
  • Coolant flush -- green: 2 years/24,000 miles.
  • Coolant flush -- dex-cool or long life: 5 years/50,000 miles.
  • Tire rotation: 5,000-8,000 miles.
  • Alignment: 15,000-20,000 miles., unless tire wear is not a problem and car goes straight.
  • Brake fluid flush and power steering fluid flush: 2 years or when dirty or discolored.
  • Air filter, pcv valve and cabin air filter: as needed.
  • Professional fuel injection service: 40,000 miles.
  • Throttle bore plate cleaning: 20,000 miles.
  • Air induction service: 20,000 miles.
MaintenanceEvery auto manufacturer lists their required maintenance on their web sites and in the owners manual the maintenance service intervals vary between manufacturers.
Your car is a moving piece of machinery, it needs maintenance, if you want this car to last you need to service it. Do not just do the minimum recommended services that are listed in you service manual. Make sure you service your cooling system which prolongs the life of the radiator and water pump, and the power steering system, which will extend the life of your cars power-seeking pump and gear box or rack. It will cost you much more than you want to spend when you fail to maintain your car and larger problems surface. I recommend that you review your owners manual and get acquainted with a reputable auto repair facility. A good relationship with you car and your car's mechanic will benefit you in the long run, providing you with a long lasting and safe car.
At 30,000 miles you should also service your cooling system, transmission, fuel system and power steering; this should be repeated every 30k miles. I recommend flushes of the later mentioned items to prolong these systems' life span.
1helpful
2answers
Toyota 4Runner/maintenance schedule at 140K miles
The maintenance schedule is an outline and should be followed if you want to keep your vehicle in good condition. the maintenance items listed in the schedule are performed at their set intervals for a reason. Manufacturers have found the wear limits on certain parts and those parts may need to be serviced or replaced at those intervals or catastrophic failures may result.
What are the service interval for items on the 2006 toyota prado
For oil and filter - every 3 -5,000 miles. rotate tires at same interval. air filter is on condition, so check it at oil change and clean it until it needs replacement. trans. fluid is on condition along with filter or I believe 60k miles. Belts and hoses are every 3 years or based on condition. Get a maintenance guide from an auto parts store or go to the dealer for an owner's manual, which will have all of this information.
Top Jaguar Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Jaguar Expert? Answer questions, earn points and help others
