Onkyo TX-DS575 Receiver Logo
Posted on Apr 29, 2010
Remote doesn't operate reciever
I have an Onkyo TX-DS575 Onkyo reciever. I cannnot operate the reciever with the remote. All the buttons on the panel of the reciever work fine. I have programed my DVD player remote into the DVD mode of the onkyo remote and that works the DVD player fine. When I switch the remote back to the Audio mode it doens't operate the the Onkyo reciever. This tells me the remote has enough power to send a signal. I changed the batteries just to make sure, it didn't make any difference.
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Nov 22, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2399
Points
I had the same issue and solved it by replacing the IR receiver on the front panel with a Rohm RPM7138-H4R which I ordered from digikey (RPM7138-H4R-ND).
Anonymous
Level 1:
New Friend:
  • Contributor 25 Answers
  • Posted on May 01, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
25
Questions
0
Helped
7810
Points
42
Hello Fixya customer,
Thank you for your question.
Please determine if the "Audio" button is actually working.... after pressing the audio button, can you still control the DVD, if not then the remote has switched to the Onkyo. Although, this is not 100% conclusive, unless you have a 2nd remote to test the Onkyo with, it provides a sound basis to proceed.
Assuming the remote is transmitting and the IR receiver on the front of the Onkyo is not otherwise blocked, likely faults include the IR receiver, input to the Micro processor, and the Micro processor.
The most probable fault is the IR receiver.
Thank you for using Fixya, and if I can help you further, please let me know.
1 Related Answer
Anonymous
  • 56 Answers
  • Posted on Jul 04, 2007
SOURCE: TX-DS575 reciever
Normally you hear a clicking sound coming from the inside when you turn on your amp. That's the sound of the magnetic circuit breaker (switch). If you tap your amp to turn it on, and if the amp gets turned on after you did it:), then I suppose the problem is on the relevant switch.
I have lost the remote control of my Onkyo TX-DS575 AV reciever/DTS Amp and cannot find one in the market. I have used a universal remote which had a couple of Onkyo codes with it but it doesn't work. Is...
Amazon.com, MyRemoteControls.com, and Remotes.com all sell a replacement remote for the TX-DS575. I have also seen the Onkyo TS-DS575 receiver with remote listed on eBay for as low as $35. Keep looking; the remotes are out there.
2answers
Onkyo TX DS575x reciever remote problem
You might try this replacement
http://www.remotes.com/remotes/servlet/rs?a=gmi&uid=11953114154530&smodel=TXDS575&brand_pn=ONKYO_TXDS575
Hi. my original remote for my onkyo tx ds575 all of a sudden is not working anymore. the red light on the remore still lights up when i press a button but the receiver is not picking it up. hopefully you...
The red light on the remote just means the battery is good and the remote is responding when you press a button. It doesn't mean the control is actually sending out a signal. Many retail stores have a tester that will tell you if the remote is transmitting. Another possibility is that the remote sensor in the receiver has gone bad, and that the remote is fine. A universal remote (One-4-All URC6131, for example) that can work home theater receivers can be used to test the receiver. It may not work all the functions, but if it turns the receiver on and off you'll know the remote is at fault and not the receiver. Then you'll be able to replace the remote or have the receiver serviced as needed.
3helpful
3answers
I have a TX-DS575 receiver and RC-391M remote control and the remote no longer controls the receiver, but it still controls all the other components (dvd, tv, etc). How can I get it working with the...
Replace the IR receiver diode on the front panel. Try HERO HIM602H from farnell.com, i used that one for my TX-DS 777. (i guess 575 using same stuff)
How do you reset the controls on an remote control for my onkyo tx-ds575
See the manual you can download on this site on page 39
1. Open the battery cover and remove the batteries.
2. While pressing and holding down the ON button and the
STNBY button, insert the batteries in the correct direction.
After inserting the batteries, release the buttons. The SEND/
LEARN indicator flashes slowly.
3. Press the ENT button.
The SEND/LEARN indicator lights up for about ten seconds,
then turns off. All programmed codes are erased and the button
memories return to the factory presets
I need the remote code for my onkyo tx-ds575, my remote isn't working and i want to program another remote to control this unit.
Get yourself a remote from Logitech Harmony family. It magically knows all the possible codes. And the support is VERY helpfull.
11helpful
3answers
Onkyo TX-DS575X, remote intermittend malfunction
You have to raplace IR sensor PIC-26043TE2 or similar and should help.
2answers
Remote control
Have you pressed the Mode Audio button on the left above the circle? This tells the remote you want to control the reciever.
TX-DS575 reciever
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
John
John
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
