Dehumid. runs and fan blows but no water in tank and never shuts off, 5yr. old maytag, only runs in summer
Several things can cause this problem. The leading one, is that the humidity extraction level is set to high. Lower it to 35%. One of the others, is a dirty or clogged air intake filter. Followed by obstructed air flow. You need to maintain at least a minimum of 12" clear air space around the unit. Also, most humidifiers struggle to operate correctly, if the ambient air temperature at floor level is between 40 to 60 degrees F. This will also cause the fan to run a lot if the unit is set in continuous mode, rather than a timed mode. And finally, if any doors or windows are open, the unit will run forever. Make sure all doors and windows are closed.
Here's an in home test to see if it's working properly. Move the dehumidifier to the bathroom. Plug it in turn it ON and set the humidity/moisture extraction level to 35%. Turn the shower ON hot enough to generate steam. Do Not turn the bathroom exhaust fan ON and close any windows that may be open. As you exit the bathroom, close the door. Wait 15 to 20 minutes before returning to the bathroom. Once you do, turn the shower OFF and allow the unit to run for 5 minutes more. Then check the bucket for any signs of water. If you find some, the unit is working as it should.
If you don't see any signs of water, the unit's compressor may need to be recharged with refrigerant.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
