It's mean your catridges overflow even from brand new catridges
after a several prints or right after you refilled the catridges. Check
to see if ink are smeared on the holder where the contact panel with
the catridge. I have the same problem which I think lexmark have a
proble and overlook.
Solution:
I use the klennex with a few drops of water to dampen and clean off those contact on the holder and my printer work again.
The
refill ink work very well if you let it sit 24 hrs. Then before you
print anything, you should run aligned the catridges a couple times
then run clean catridges a couple times.
Print the test page to see how it's look and way you go.
Be sure not to leave any debris of klennex on those holder contact panel.
Dell Series 5 ink cartridges have a sensor in them that cannot be reset.
Article on refilling Dell ink cartridges.
Dell Series 5 ink cartridges can be purchased at Staples, Walmart or
Dell's Website.
regards
iversh
A very helpful rating is appreciated for answering your query...
I don't actually recommend refills as they most of the time damage the printer. How many times have you used this cartridge for refills? Error 1203 is a cartridge error.
