SOURCE: Computer will not recognize my Navigon 7100?
If your useing Windows XP or Vista,drivers arn't needed..Windows "sees" the gps unit as another drive.
If you want to use the logbook , the files are in excel format.
the owners manual shows where the files are stoerd on the memory card!!
SOURCE: navigon 7100: Fatal error popped up, now it stuck
Take out the SD card, if that dosent work Ty plugging it into a
computer sometimes that will reset it. I believe it is a problem with
the maps when i got the updated second quarter maps it quite doing it.
I none of the above works, let the battery die and take out the SD card before running it on, then reinsert the card and it might work for awhile
SOURCE: Lost password lock on Navigon 7100
forget it if you dont have the unlock code its useless and may even be hot!
SOURCE: Navigon 7100 Fatal Application Error
I have same problem I went to their website. www.navigon.com/site/us/en/my_navigon. In there you register your device and also in freshmaps put your Freshmaps code to activate.once activate download updated software from the windows of maps and software in Navigon 3 windows.You will find picture of your device hit on that picture to downlaod software update in your computer to save to your desktop.It will take atleast 45 to 1 hour depend on speed don't turn off cmputer in between.
Than get 4 gb sd card put to slot to your computer either directly or through Card reader whichever it suits you .when card is in computer wait till it shows removable media inserted.
Than hit on icon on your computer desktop where you downlaoded software update, mesasage box will appear to download to sd card hit yes it will download entire software wait till it says downlaod complete.
After download complete go back to same website and hit on window says software updates hit on that and it will downlaod most updataed version of software to sd card.
After completion of downlaod completion romove sd card be carefull to check on that says eject sd card hit on that than remove the card after otherwise it will destroy the pogram in sd card.
Put your sd card to device and there you go it will work.
Since new software is large and it requires more space than old one ols card will not work even after download of new software.Please buy 4 gb sd new card and follow the procedure.Since new software consumes almost 2 gb I recommend to purchase 4 gb sd card .please don't buy micro sd card with adapter it won't work.
