Under the battery cover there are 2 potantiometer which looks like screw , play with them carefully til you get clear picture , if they dont wortk you will need to replace your screen
If you get the bottom screen wet trying to clean in with Windex or something it will get in the screen and cause grey areas. if enough gets in it will cause the whole screen to look grey/dull
SOURCE: my nintendo ds lite top screen isn't working properly
Top LCD's flex cable that passes through right-hand hinge into bottom part of case will be damaged or not properly seated in its connector socket.
SOURCE: broken nintendo ds lite screen
Contact Nintendo about product warrenty. If it is still under warrenty, I highly suggest you send it to them for them to repair. If the warrenty has expired, you can contact Nintendo to check for replacement parts or to find out their policies on equipment repairs.
SOURCE: nintendo ds lite screens blank, although green power light on
possible that the flex holding the lcd is broken.
