When the unit is switched on there is a loud ratchet type noise for about five seconds. The noise is repeated when selecting a print 'job' The unit works perfectly for the period of that printing.
The noise is coming from the left hand end immediately behind the operating switch.
The noise is loud and disturbing.
HELP !
Ron Warburton
[email protected]
Hello Warbie2 ,
Your issue may be the laser/scanner motor. Usually
sound like a jet engine warming up when starting to print and then has
a whinning down sound after the paper has printed. Usually you need to
replace the complete laser/scanner assembly. On some models the shaft
of the motor can be lightly lubricated but I yours I do not think so
and if you use to much you will destroy the optics.
