Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
Posted on Mar 24, 2008
Canon Ixus 75 not charging
The camera was working fine 2 days ago. Yesterday when I tried to switch it on, I assumed that the battery was flat so I charged it but when fully charged the camera still won't switch on. Please help!
  • daveod Mar 31, 2008
    I have the same problem with my Ixus 60 .... tried 2 fully charged batteries but won't even switch on --- totally dead !!
  • Anonymous May 25, 2008
    The camera canon ixus 60 was working fine 3 days ago. Yesterday when I tried to switch it on, I assumed that the battery was flat so I charged it but when fully charged the camera still won't switch on. Please help! help
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 25, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
589
Points
bob
    The camera canon ixus 60 was working fine 2 days ago. Yesterday when I tried to switch it on, I assumed that the battery was flat so I charged it but when fully charged the camera still won't switch on. Please help!
A
Anonymous
The camera was working fine 2 days ago. Yesterday when I tried to switch it on, I assumed that the battery was flat so I charged it but when fully charged the camera still won't switch on. Please help! bob
A
Anonymous
The camera was working fine 5 days ago. Yesterday when I tried to switch it on, I assumed that the battery was flat so I charged it but when fully charged the camera still won't switch on. i Please help!
I have a cannon ixus 75 can i charge it from a laptop
Probably not, USB does not provide enough current to charge this type of battery, ergo Canon does not support USB charging. You can buy a third party charger and battery set for not very much and keep this camera working.
My canon ixus 75 has no power.
There are many ways to troubleshoot this problem.
First try to insert new batteries and then tap on the sides of the camera and turn on the camera. It will switch on if the problem is due to loose connection.
Secondly, clean the battery terminal before inserting new batteries and check through a multimeter, whether the battery terminal is receiving the power properly from the battery. If there is no power, you need to contact canon to get the element replaced. If there is power in terminal and still not switching on there is some chance that lens is stuck inside, and it is not allowing to switch on. So clean the lens and try to turn on the camera it will work fine.
If you still have the problem then it tends to be the problem of the circuit board inside the camera.
Hope this helps.
Shane
It wont capture a picture anymore. it was working just fine.. it tries to take it and the orange light comes on but it wont take
try to replace the battery, with a fully-charged one, if still it won't work, bring your cam to a service center
2helpful
The camera will not turn on.
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
2answers
PowerShot SD750 / IXUS 75 Digital Camera: HOW DO I CHARGE MY BATTERY...
Take the battery out of the camera, put it into the supplied charger, and plug the charger into a wall outlet.
SD750 not turning on
Did you reolaced battery that evening, if you did then try holding the battery door tight and the turn it on. If this will solve it it means that there is a play in battery door that happens very often if someone is not careful enough while replacing battery or merory card.
1helpful
Camera will not turn on. Battery fully charged;
You can give it to an expert for repair, he can repair it for less as there must be just a fuse problem, which can be fixed for a very less amount.
Ixus 75 battery discharges overnight even if the camera is turned off.
That's it, the battery's defective, it's not the camera...unless you've tried another (new) battery...
6answers
Help
Wow, this is trully amazing. I went to do a search on why my camera wouldnt turn on the past couple of days, even after i charged all THREE of my batteries and found similar complaints within the same time frame!! WOW. We need to get together and fight this, cause its suspect!!! I bought mine in Mass, anyone else?
2answers
Help
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
