Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front loader wont start
The dial was turned in the middle of a cycle and now wont start, I have tried turning it off and on at the power point and leaving it off for over and hour. The water has been drained out via the filter.
  • 1 more comment
  • needsawasher Apr 04, 2008
    THE MACHINE LIGHTS UP BUT WILL NOT START THE WASH CYCLE. THE LETTERS dl F SHOWS UP ON THE DISPLAY.
  • onecrazychi Mar 09, 2009
    I was washing a load got a high pitched beep came to look and the washer had turned its self off now it wont come back on or unlock.it is a whirlpool duet front loader
  • Ron Coons
    Ron Coons May 11, 2010
    what exactly happens when you plug unit in and set ot for the drain spin cycle and try to start it??? does it read 12 min in the display at least??
  • 185 Answers
Try plugging it back in and hit cancel
Posted on Mar 31, 2008
Anonymous
SOURCE:
How do you get it to wash
plug power cord into power point and turn on power point
turn dial round to cycle
then make sure door is closed
A model number and make of washing machine would enable a more specific answer
Aug 15, 2016 | Washing Machines
GE Nautilus wont start
Looks like you need to replace the timer/cycle panel on your appliance.
Try first unplugging machine for 20 minutes, to see if this reset can fix the problem.
Aug 28, 2008 | GE Nautilus 24" Built-in Dishwasher
Washer won't work and door is locked shut with clothes inside. Can I get the door open manually?
turn off . turn off power point. Wait 3 minutes then turn on power point. Try blowing on drain pipe then turn dial to spin cycle .
See if water pump is engaged during spin cycle.
Don't know if you can manually open the door
Had a similar problem and found the water pump was not pumping the water out and spin cycle was failing to complete.
Check filter of front loader as well .
Mar 19, 2016 | Washing Machines
How do I dry only
When using the WD-1000 as a Dryer only, are you turning the rightmost knob Clockwise to the correct starting point?
Looking at the periphery of the knob, at the bottom, see the elongated "sausage" shape, outlined in blue? Turn the knob so it passes "Stop", and points there.
At the end of a completed Wash Cycle, that is where the pointer will be pointing. Once there, the machine switches automatically to Dryer Mode.
As long as the middle dial is set to a timer length greater than zero, the drying begins. I recommend turning the middle dial to somewhere around 2:00 o'clock, which corresponds to about 90 minutes if I remember correctly.
(You'll notice that is in the "Orange" area, meaning Full Heat - which is always fine because it never gets too hot anyway)
So, turn right dial to point to the "white sausage" at the bottom of the dial; Turn middle dial to 90 mins, or so; (Left dial only controls "Spin" speed - just set to max); and close the door. (It should begin drying)
Feb 14, 2015 | Malber WD1000 Front Load Washer/Dryer
Washer will fill up and then nothing almost sounds like the timer
I assume the timer is mechanical instead of electronic--try turning the dial slowly through the full cycle positions. You should get motor operation at some points along the dial. If the motor never reacts, look for a circuit breaker button on the motor near it's wiring entry. With the power plug out, try turning the motor shaft to make sure it is not bound up. If the motor does run at points, then probably the clock motor on the timer is bound up.
Aug 02, 2009 | Washing Machines
Beko wma1510s washing machine dial problem
my beko wma 1510s will not spin and is heating up
Apr 11, 2009 | Washing Machines
Hot point wmlt80, dail clicking and turning, cycle wont start,
Yes, I work for GE what you need to do is to resent the appliance. Something should had happened with the computer of the washer. Just unplugged the machine for 40 seconds. You can unplugged or turn off the circuit breaker for 40 second and plugged back in. Select a normal cycle and let it run.
Jan 15, 2009 | Hotpoint WMTL80 Top Load Washer
Dial continuously turning
hiya
to reset the dial, switch the power off, then turn the dial to a dot on the selection then switch the power on, the light should flash about 3-4 times this should be it reset.
for the machine to start doing this mid cyle though usually indicates something is wrong, i would hazard a guess at the pump filter is blocked and the mahine was trying to drain at the time it started clicking.
the best thing to do is empty the machine manually by placing the outlet hose into a bucket or large dish, once empty remove the plastic kick plate on the bottom of the machine and behind this you will find the filter.
before you unscrew the filter you will need to place some towels or old cloths on the floor as there will still be water left in the pipes, remove filter and any foreign objects (possibly coins, hair clips etc) and then screw back in. job done.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Aug 02, 2008 | Ariston Technologies Ariston AWD12 Front...
Whirlpool Duet GHW9150P Front Load Washer Logo
140 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
