SOURCE: Danby DMW753W 800 Watts Microwave Oven Problem
The touch pad may be defective. There is a membrane behind the buttons that will cause problems like that. The only cure is to replace the touch assy.
SOURCE: chefmate microwave P70D20AL-D4 beeping
After calling many numbers, I was put in contact with the manufacturer, Galanz Microwave, and was told that that beeping is due to a burned out part in the keypad that is not servicable. I, too, have this annoying model!
SOURCE: buttons dont work on danby microwave
I had the same problem, but only with 4 buttons. The 3,6,9 & Start/Stop button stopped working.
Hard reset & leaving unplugged did not work. Eventually, I tried picking it up and dropping it from several inches, and smacking it on the side. That did the trick. Works great now!
