Hi...the yellow haze is probably the blue filter is burnt and needs replaced. This is very common in Zeniths. There are 3 color filters in the Zeniths blue (pinkish in color), green (grayish in color) and the red (it is red). The #1 problem in this TV is the blue filter is burnt and it is an easy fix. It could also be the LCD cube is bad. I would try the blue filter replacement first. It will probably do the trick.
Hi - we've had the blue filter of a 5 year old JVC 60inch rear projection TV burnt out after replacing the bulb. Seems even the JVC techs in New Zealand cannot get a replacement part and we have been quoted $A3900 for a whole new engine sourced from Australia. Closed shop - they won't even give us the part number for the blue filter so all our TV is good for now is being used as a boat anchor. Really gutted and if anyone can help, would be much appreciated. Regards, Karen
SOURCE: Yellow Haze Center Screen
The blue filter is burnt out. A very common problem in Zenith DLPs. There are 3 color filters, 1 blue (a pinkish color), 1 green (a grayish brown) and 1 red (it is red) they give you your colors for you picture. This is a simple fix.
SOURCE: yellow haze on screen
the optical block has failed. see this site for complete info..
http://sites.google.com/site/sonylcdrptvproblems/
good luck
Where does one go to buy said blue filter. Does anyone have a repair manual? I am good with fixing this on my own, but it always helps to have a manual to fall back on.
Thanks!
I have this same yellow haze on my set and looks like the menu is burt in to the scrren in a blue tint - you can only seeit when its a really dark scene - anyone got any idea??
