Question about Canon PIXMA iP90 Mobile Printer
Full ink cartriges print a few lines and skip a few lines
I have gone through 4 brand new ink cartridges, and I can't print a single full page. Each page is printing some full lines, half lines or skipping lines at the exact same part of the page. I did have a paper jam preceding this problem, but it printed the previous document perfectly after I fixed it and it is only every subsequent document that is not printing correctly. How do I fix the problem?
    New Friend:
I had the same problem, IP4500 skips several lines, prints same amount of lines, then skips, then prints. Test page prints fine but it has skipping issue when printing word document, or print shipping label. I'd tried deep clean the test head, and manual clean it with alcohol without success. The following fixes the skipping issue:
1. Open the printer so the printer inks move to the open space.
2. Unplugged the power, now can manually push the inks to the left.
3. Two pads to collect the ink is on the right, take them out and clean out the ink with water and dry them.
4. Clean out the ink pad holders and areas around them with cotton swap and alcohol.
5. Refill all inks and plug back the power.
The above step fixes skipping line issue.
Posted on Jul 24, 2016
    Genius:
  • 3,587 Answers
Well..did you run a test page?
or clean the print heads?
or recalibrate them?
recommend all these steps for you
and as my 2200th solution, you are entitled to a FREE tuneup for good. find out more about that service here
Posted on Mar 24, 2008
6ya staff
SOURCE:
How do i change an ink cartrige in a canon 160 printe
The Canon Pixma inkjet printer is an all-in-one printer, scanner and copier capable of printing high-resolution photos. One handy feature is a slot for a memory card so you print photographs directly from your camera. It can also print completely without any border for full-sheet photos. Printing photos and other high-fidelity documents uses up ink more quickly, and you will probably need to replace at least one of your cartridges every three to six months, a process that should take you about three to five minutes.
1.urn on the printer and check the LCD screen for an indication of which ink cartridges are low. Note that recycled ink cartridges sometimes read "Ink low" even when they still have ink, so print a test page if you're not sure.
2.Expose the ink tray by lifting the entire LCD control panel, which is attached to the underside of the copier tray.
3.Pull out the used ink cartridge by pulling straight up from the print head, and dispose of them safely and carefully by putting them in a sealed bag.
4.Remove gently any packaging from the new ink, after giving it a few shakes. Pull off the protective tab on the cartridge, insert the new cartridge into the print head and push down until you feel a click. Close the printer lid and let the printer reset the ink tray.
5.Print a test page to make sure the new ink works. If it doesn't, you may have forgotten to remove the protective tab under the cartridge.
Sep 06, 2011 | Canon PIXMA MP160 All-In-One InkJet...
HP all-in-one F380 only prints top half of the page, and sometimes that is pretty faded. What to do?
Replace the ink-cartridges, because they are just about empty.
When ink is pulled from the cartridge, there is just enough ink to print a "low-density" page,
or a few lines of text, but there's not enough ink to "freely" flow, on demand, to ink a full page.
Jul 30, 2011 | HP DeskJet F380 All-In-One Printer
How to troubleshoot printer
Printer icon still in ur computer,u tried to print a page,printer beeps or shaking of gears about to print,but never did?Yes.How long is the inks cartridge or cartridges been in ur printer?Like a year?Yes.Doesn't matter how many pages u printed even only few pages,the the inks cartridges is dead,it out dated and the cartriges it dry up.Requiring new inks cartridges.Pinters manufactures all of them make their money not on the printers hardwares,it so cheap alot of printers like they giving it away,but the inks cartridges themself cost u like $40 to $50 bucks for a pair of inks cartriges and the expiration date only a year.That if only u printed like 40 pages or less or those cartriges will run out inks before the expiration date.
Jan 27, 2011 | Televison & Video
Canon MP 610 printer. Cartridges half full when forced to replace
well printers calculate ink, with printing jobs. If you exchange cartriges in the middle of these ( ex:you exchange cartriges about after 100 print jobs and the cartriges is 500 top) the printer dont know excatly the ink level, so gives these error on calculation, not exact ink level. so you need to take out and place again to reset cartridge counter.
Jan 16, 2010 | Office Equipment & Supplies
Canon MX850 Large Black Ink Cartridge - PGI-5BK problem
Just bought new MX318 one chamber gets finished after a few pages. No indicator for finished ink. One compartment of Ink cartridge looks empty the other still full. Tried cleening process but no improvement. Replaced Cartridge but it seems to behave the same as the first after a few prints.
Aug 03, 2009 | Canon PIXMA MX850 Multifunction Printer
Ink low indication on HP Deskjet F4288
hi im josh in cebu phils.may i help you? Friend the problem is the ink level dropped 3/4 after printing 7 pages and low exclamation mark in red. Friend it is the real deal since you are using a free ink cartrdge with your printer that ink is only a sample one and the content of that cartridge is not full thats why it dropped to empty in just a few pages of printing. It just appear full in the ink level monitoring since the printer auto detects new cartridge on the tank. It is just so You need to buy a new ink cartridge the one with the full content.and i'm sure it will last a long time since it is already full. thats all friend good luck hope i helped you.
Mar 14, 2009 | HP Officejet Pro L7680 All-In-One Printer
Print Cartridge Problems
i have an mp170 all in one and when you fill the cartriges they dont show up as full cannon put a chip in the cartridge to con people into buying new ones try siting the cartridges in warm water for a few hours then blot the cartridge with tisue paper if it dont blot out the ink the cartride is finnished and you need a new one .To align the cartridge you flick through the menu on the printer not pc screen look for alignment page print this off then you have to pick the dark boxes on the sheet shade the bit next to it and put on your scan bed and click ok it should scan the sheet and reset the alignment
Jul 19, 2008 | Canon PIXMA MP180 All-In-One InkJet...
No black ink print. Prints in light blue
Cartriges have a shelf life. It's printing in blue either because it has dried up or is out. Different cartriges have different timelines but if you haven't been using the printer often, it could have dried up or is simply out of ink. I would suggest first to try cleaning the head of the cartrige where the ink comes out with alcohol and a Q-tip and then if that doesn't work, buying a new black cartrige.
Nov 06, 2007 | Office Equipment & Supplies
Streaks / Bands of broken print area
First with a clean soft cloth and a very small amt of alcohol clean off the underside of the printer carridge (the holder for the print heads) also where the print heads cleaning station is clean out any large masses of congealed link. Then remove the ink cartridge in question and with a pencil eraser gently rub the contacts and both the cartridge and the carridge replace the cartridge. Using the software tools for the printer clean and align the printheads ( if there is an option to do so). If this dosn't fix the problem try a different ink cartridge.
Sep 04, 2007 | HP OfficeJet Pro k550 Printer
Canon PIXMA iP90 Mobile Printer Logo
1,369 people viewed this question
Clive
Clive
old marine
old marine
Ekse
