Agreed with Richie46. He beet my to the answer. Do not use a spray can for cleaning it too you can damage the print head.
Printer software will have a menu for cleaning the heads when they get dirty or clogged. Try that. You can also , if possible, remove the print head and soak it for a few hours in cleaning solution.
SOURCE: Kodax Eps-5 Printer want print with one cartridge
No you need functioning colour cart for black to work.
SOURCE: Won't recognize color ink cartridge
This is a common problem with Kodak 5000 series and ESP series printers.
Check the silver contacts on the ink cartridges for small scratches in the center. The scratches indicate that the ink cartridges have made contact with the appropriate connections in the printer. If no marks are visible, the cartridge was not seated properly. If the contacts look ok, you'll have to call Kodak again. It's highly likely that the recertified printer you received was returned for the same problem. If you point out the fact that you are experiencing the same problem for the second time, you may wind up with an upgrade to an ESP5. Don't accept another printhead replacement as thiat will not resolve the problem.
SOURCE: put in new color ink cartridge still showing as
Where you can see the light indicator that the color ink is empty on your computer or on the printer itself? If on the printer itself I believed that you have a flashing redlight on the printer., Now please try to reseat the color Ink cartridges 2 times., you may also try to remove the Printhead., By doing that remove both the ink cartridges and followed by the printhead. now if you already done and still you have that flashing redlight call kodak Toll free at 1 800 421 6699 For US support.
Now if the empty ink cartridges shows only on your computer it means that you need to re establish the connection of your computer and your printer you need to call kodak and they will assist you how to do the reconnection
SOURCE: how can I over ride my ink level tracker on the
The Kodak printers are designed in such a way so as to work with combination of Both color and black ink..In other printers,the prints are not that sharp,but In kodak printers color are awesome because even if we print black and white,the color from the color ink is also taken to give you those lifetime prints.Unfortunately There is no way to overcome this ink indicator.You cans et the preferences in the printer settings to print in black and white in your computer .
