F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Hello Yves Trottier, thank you for your post!
I understand that your Frigidaire range is displaying the error code "F93". Typically, "F93" stands for maximum over door unlock time exceeded. This could be a potential issue with EOC (Electronic Oven Control), motor door latch assembly, or fan motor. I would recommend performing a reset on your range which consists of you disconnecting power from the range for approximately ten minutes. If you continue to experience such issues I would suggest consulting with a professional technician for proper diagnosis and repair. Hope this information is helpful. -Matt
Hi - Typically error code F93 indicates a communication problem with the console control. Since you have already try to reset the unit and unfortunately it was not successful, I would suggest contacting a professional to move forward and replace the main control board.
