I am unable to make wireless DLink modem DI-524 talk to the cable modem(Scientific Atlanta). I have tried various things like resetting cable/wireless modem, different encryption standards, etc. None of the options seem to be working. Can any of you guys came across the similar problem or know the root cause? thanks in advance.
As soon as you get access to the Netgear Nighthawk router login page, you can change the following basic and advanced settings of your router with great ease:
Generate cool font styles for your social media bios, chats, comments with our fancy font generator. This tool converts your input text into more than 500 styles in an instant. Visit the web-based platform or download the Font app to get started. https://coolsymbolfonts.com/
Overcome poor network signals in your home with the dlink extender. You don't have to always stick to a particular location in order to benefit from a fast internet speed. With the D-Link WiFi Extender Setup in your house, you can increase productivity and multi-task without any kind of disruption.
he is waiting , in bated breath, pant , pant , since?
Posted by rrenukumar on Oct 25, 2017
That is an extremely old ROUTER and has been discontinued for almost 10 years now. Does the modem provided, the scientific Atlanta, have WiFi? Are you trying to use the Dl524 to extend this WiFi? If thatās the case, it will not work. DLink will only extent other DLink WIFI devices.
If youāre trying to use this router because the Scientific Atlanta does not have WiFi, ensure your Ethernet from the modem is connected into the proper data port for the router.
You can reset the router by taking a pen and holding the reset butting, unplugging the router (while holding the button, wait about 20 seconds, and plug the router in, then release the button. This will completely reset the router to defaults.
The routers default setup address is either 192.168.0.1 or 192.168.1.1. Use the setup wizard. If it still doesnāt work, itās not a compatibility issue, the router has probably given up the ghost due to its age.
I would suggest downloading the manual and check the settings for your country.. it can be found here.
http://support.dlink.com/emulators/di524_revc/h_lan.html
SOURCE: WEP Encryption
It is recommended to enable encryption on your wireless router before your wireless network adapters. Please establish wireless connectivity before enabling encryption. Note: Your network will slow down and wireless signal may degrade when enabling encryption due to the added overhead. Step 1 Log into the web configuration of the router by opening up a web browser and typing in the IP address of the router (192.168.0.1). Step 2 Enter your username (admin) and your password (blank by default). Click OK . Click the Home tab and click the Wireless button on the left hand side of the screen. Step 3 Select Enable next to the WEP radio buttons. For WEP encryption select 64, 128, or 256-bit encryption. For the Key type select HEX. If you have an option for Authentication type, select Shared Key. Step 4 Select Key 1. Enter a Hex encryption key that you make up. The length of the encryption key will depend on what you selected under WEP Encryption. 64-bit encryption 10 characters 128-bit encryption 26 characters 256-bit encryption 58 characters (available on DI-614+ only) The encryption key is HEX, meaning 0-9 and A-F are valid characters. For example, A4583DFF1A (64-bit HEX key). Step 5 Click on the Apply button then click on the Continue button to save your settings. Note: If using non-D-Link adapters, please refer to the manufacturerĀ“s documentation on enabling encryption.
SOURCE: method of connecting Dlink wireless router DI-524 to computer
On the back there should be a reset to reset to default settings.
SOURCE: Dlink DI 524 failed firmware update
You need to hold in the button on the back with a pen for 10-15 seconds, and then release to set the router back to its factory settings -- then try the update again.
SOURCE: DI-524 status led not blinking
Here are the instructions
Hope this helps.
Also you can visit the link :: support.dlink.com/products/view.···DI%2D524 for further assistance
Please rate this solution!!!!!!
