My Sceptre monitor x20wg-nagall power light come on but no display.
This unit is not getting a signal or is defective.
Make sure the VGA cable has all the pins or try another. Make sure they are plugged in good. Try the monitor on another computer. If it still doesnt work then the monitor is bad. Only a technician with the proper equipment can fix them but it is rarely worth it.
First check the cable ...there can be always something wrong with them ...second..to be sure that the monitor is to blame ...hook another one to the computer and see if it works...also ...you may tell this if the actual logging sound is heard when you open it ...but even in this case the computer nay be ok ..and you just messed up the video card ...setting s..or the video-card itself....so ..either trying another monitor(even an old one ..just to see if it is th monitor to blame or the computer ) or try the monitor in another computer ...(if you have a laptop you can hook it as second monitor ,, and press Fn -F4 to activate it ..)
i fthemonitor turns up to be ok ...the issue is in the video card ...
first open and see if the card is proper inserted in the slot...push it down a little ..or get it out and insert it again ) ..if this will not brink it back ...try the on board card ...if the computer has one ...but for this to work you have to remove the pci one ..) ...there may be the case thet you tried some settings that the computer do not support on the card ..and now you will actually need to insert in the on board card ...and remove the video driver ..insert the other card again ...and reinstall the driver ...I did had this kinda problem with a video card ..and I meesed some settings on it ..and it shows up black after reboot..removing the driver it was te only way out than ...and my lack was tat I had a on board card ...if you do not ...and the monitor seam ok ...you will have to try to reinstall it ..I mean the computer ..
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Basic LCD monitor troubleshooting guide:
The problem is with power supply or inverter board for the monitor not the video card on the computer.
My Sceptre X20WG-NAGALL monitor power light come on, but no display. Mind you that I tried this monitor on more than one computer, I also swapped monitors. The problem is internal. I opned the monitor and found four bad caps (bulging). I replaced them. Still the same problem. Can you help me?
