Washer sticks on wash cycle; runs continuosly on spin cycle
My washer sticks sometimes on the wash cycle and just pours water in to the tub. Almost every load the water continues to run and eventually refill the tub throughout the spin cycle. The wash cycle ends having run through the whole load, including the drain part with a tub full of water. Please help!
Re: Washer sticks on wash cycle; runs continuosly on spin...
That sounds like you have one of them fancy water saving outfits with a diverter valve that dumps the pump water continuosly over the clothes. Weirdest washer I ever saw. Could be the solenoid that opens the drain pump has failed. Don't know too much about em but I do have the service manual. Post your model number for a more precise answer. Whirlpool Catalyst washer manual
Hi agnes!
Washing
machines, including those built by Frigidaire, have internal pumps. These pumps
help drain out the water from the washer tub between the wash, rinse, and spin
cycles. If the pump is damaged or the pump pulley system is frozen/stiff, the
water can become trapped in the washer tub. In both cases, the pump assembly
needs to be replaced. You can check by looking for a few signs that a pump is
dying or already dead.
1 Start the washer and wait for the washer tub
to fill with water. If you do not hear water or hear a motor whirring, the
washer motor may be dead.
2 Open the washer lid in mid-cycle. Note
whether or not the inner tub is still spinning around. The inner tub is the
inside surface of the washing compartment with many holes for water draining.
If the tub is not spinning but the motor is running, it is possible the pump is
dead. Check the pump pulley by removing the pump from the washer and trying to
rotate it by hand. If the pulley doesn't turn freely and is frozen or stiff,
replace it. Also, if the agitator is moving but the tub isn't, this is a sign the
pump is dying. For front-loading washers, do not attempt to open the door
mid-cycle. Look through the glass door. If there is enough water to come up
against the door, the pump is malfunctioning.
3 Wait for the washer to finish its cycle. Open
the unit. If water is still in the tub, the pump is likely dying or dead.
It won't drain If your washer won't drain, check these: It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
The cycle doesn't advance
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
what's the brand name and model number,all washers are different,most likely it's the motor humming or the pump is humming,could have something stuck in pump,if the water doesn't drain the washer won't spin,if you have a shop vac pull the drain hose out of stand pipe or sink,stick the shop vac hose onto the drain hose,get it down as low as you can and suck out the water and then see if it spins,if there's alot of water in the tub suck it out of the tub first then go to the drain hose,if it spins when water is out you know it's the pump but if you say water is still in tub i would have to say it is the pump,
Problem fixed. I took apart the bottom of the washer to access the pump, and found that there was underwire from bras stuck in the discharge tube blocking the water from exiting the washer and that was causing the cycle problem. I guess that the washer knew that there was too much water in the tub and kept trying to expel it.
I had the same problem, you need to turn the washing machine on it's side and look for a pin hole leak in the seam of the plastic holding drum on the bottom. I used a silicone sealant, "GOOP" , let it dry for 1 day and problem solved. It has not leaked in two years. good luck!
